Battery charge?
To add I may have found a way to test the alternator
All accessories on heated seats steering wheel forgot the rear seat heaters vehicle off.
Vehicle off opened door so everything off
Sent from my Pixel 4 XL using Tapatalk
Vehicle off all accessories on before voltage fully read dropped.
I'm really hoping this isn't accurate but that may explain the real reason my battery dies and have to trickle charge it all the time.
I tried placing a screw driver behind the alternator to see if it would magnitize and nothing and just thought maybe something is different with new alternators since Ford said they tested it was fine.
But 12.6 should be 90%
A few things to keep in mind ...
The OBD port data will always be compromised when testing electrical components with the vehicle off unless you know which modules are being activated.  The ignition has to be ON before OBD data can be read.  That by itself may be setting off a cascade of events, sort of like a computer preloading programs in cache.
The best way to know if there might be an issue is to use an amp clamp on the battery cables and record the values it shows when the vehicle is completely off.  You will see some pulsing at least for the first 8 hours as the PCM checks the battery - part of how the Battery Management System works.
Checking individual fuses for current draw or voltage drop is difficult with Maxi Fuses because there are no test ports for use while installed.
If you want to test your relays, a good way to do it is to unplug the charger without turning it off first :D  Worse the higher the rate of charge.  Yeah, I did that one time accidentally.  Several moments of anxiety followed.  Still seeing a therapist.
I remember seeing something on the cables that looked like a permanent amp clamp so I was curious if it would be in forscan and it was but yeah it's probably on the side after the battery and not alternator side but I also couldn't find it again. Don't remember where I saw it
