Black center caps for 20" 2011 SHO wheels
TwinTurboTom
Anyone know where I can find a set of gloss black Ford logo center caps for my 2011 SHO? I have the 20" wheels. I can't, for the life of me, find a set that fit on ebay - or anywhere else. I purchased a set of 67mm, and they were too large. At a minimum, anyone know what size cap it should be?
Well:
Here is the correct P/N 97BG1000AD,  for the Blue Center cap (we had them powder coated Black)
and then the center painted white (turned out awesome) however they are a b*tch to install without
breaking off the tabs, I found an Additional set of four (4) not in the best shape for 20 buck delivered
(from England).. New ones are Pretty pricey however (like 50 apiece).. So be patient....
I used a high gloss spray paint... several coats and they turned out fairly well...
ZSHO said:
Did you try this site? Z
http://www.hubcaphaven.com/p/4653/c3625-ford-ranger-flex-taurus-oem-center-cap-3l241a096aa.html
The oem calls for 68mm.IDK
Part Info
Part No. 97BZ-1130-AA
Base No. 1130
Part Description COVER - WHEEL
Blue , Ø 68MM
Require Quantity 4
Package Quantity 1
Replaced By 97BZ-1130-C
https://www.fordpartsgiant.com/parts/ford-cover-wheel_97bz-1130-aa.html?Make=Ford&Model=Taurus&Year=2011&Submodel=&Filter=(38591;30393;43021;28765)&Location=wheels,,1130
Yea... but I scoffed at the price ($180 for a set of 4 black!!!) when I can get what I would think is the same thing on ebay for $20. But, as I type this I just bit the bullet and ordered them. We'll see if they fit. Thanks!
FWIW found a used one for backup purposes.  Z
Best of luck TwinTurboTom  and hope they fit like a glove.
6F23-1A096-BA $14.24 ea  2-5/8"
http://www.ebay.com/itm/Fit-SOME-Ford-Edge-Explorer-Flex-Taurus-center-cap-6F23-1A096-BA-2-5-8-black/131903884776?_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D41375%26meid%3D943f66cb115a4ea6a0f50910085524fa%26pid%3D100005%26rk%3D4%26rkt%3D6%26sd%3D381371120582&_trksid=p2047675.c100005.m1851
Got another option for ya OP, and anyone else interested!
Go to a local junkyard. You-pull-it style is better than they-pull-it but either will work. Ask what they have. You can probaby find a set or 2 or 12 for dirt cheap. I have ~15 of the stock style and 3 or so black ones at my parents house from various junkyard trips. Many Fords use the same size cap.
