The wastegates should be in the closed position AFAIK!
In your case it sounds like one or more wastegates are maybe stuck open or sticky wastegate.
The noise your hearing could be related to your issue!
I would also try to disconnect the PCM connectors and inspect the wiring harness for corrosion and clean it with some electronic or air mas flow cleaner.
Car wash (auto) or heavy rain recently! Z
[PDF BELOW]
https://drive.google.com/file/d/0B8JUL90DXgdidFg4ZmN6SzF3cVVueGo2TFNSNUtfamJPcllN/view?usp=drivesdk
[PDF BELOW]
