Hi all,
New and have been slowly tracking problems with my SHO (unleashed 93 tune currently). For a good while I was having up to 22psi boost spikes and I found 2 leaks that have been repaired now (throttle body hose clamp was stripped and vac line going from boost solenoid to charge pipe).
My boost levels have been ALOT better in the past two revs of the tune but I wanted to see what other Unleashed users were experiencing as far as a +/- of boost. Lately I am anywhere from +/- 0.75 of my 15 psi target. My fuel pressure seems to be better (not sure still if I am positive on acceptable levels through the powerband yet though) and my OAR is stuck at -0.96 so I believe my fuel is good.
Running a standard 93 (e10) what is normal lambse for banks 1 and 2? I have been trying to educate myself on some of these as I am still new to these cars. Also what is the reason for 2 banks of lambse?
thanks!
thanks!
