Brad and I are looking at my logs and he is seeing a large boost spike. He thinks there is a issue with the boost solenoid(s) but he is unsure if there are one (on top) or two?
Any ideas much-smarter-than-i-people?
I'm not super certain and in the log I looked at it only shows 1 bank not both. Unless I'm chasing a problem I only look at 1 bank in my standard config. I wouldn't bother with the secondary 02's they just monitor the cats. But honestly for how you run the car and spraying meth and your car is a 2010 I would replace the primary 02's anyway. But in the log there was a spot during WOT where it went flat on stft's and that can be an indicator that the primary 02's are on the way out.
But besides all that, the 02's aren't your problem. And you seemed disappointed that the ECU detected no misfires. It appears to me that's because there were no misfires. In those last 2 logs you are overboosting. And there are a few different ways that the ECU will try to control that. Could be throttle, spark, wastegates. And that's probably the noises you were hearing. If you are certain that the vac lines are ok and the boost solenoid is ok then you could have a sticky wastegate...Your car is a 2010 so there have been thousands of heat cycles.
You will never see boost rising at the top like your's was....Something is not right with the boost control
I'm not sure if there is 1 or 2 boost solenoids
