Cincinnati Area Maintenance
jeffrey13 said:
Ok so after 3 PTU seals they are replacing the PTU today! I was curious if there is anything I should look for after the replacement other than leaks of course. Thanks!!
Make sure it's not your turbo that's leaking oil since the seals aren't fixing anything.  It might not even be your ptu at all.  That spot is right below the rear turbo.  As you drive, the oil can be blowing onto your ptu shaft.
