Did anyone not have their separator working? I'm still skeptical as it is only catching fuel vapors (very light petroleum vapors) and not actually engine oil. This stuff would probably burn fairly easily if ingested into the intake manifold.
For the cleanside, I'm just running that breather filter. The RXSpeedworks cleanside separator is basically an oil cap with 2 layers of mesh to prevent oil from seeping out of the vacuum tube. Their instructions say to drill and tap a barb for your airbox, or if you don't want to drill the airbox, you can mount a pod filter - which is basically the same as using a breather filter on the valve cover. Even though the airbox top is about $40 (AA5Z-9661-B) I'd rather not drill into it.
