If you like using Mobil 1 then you should use 5w-30 labeled on your oil cap along with a Motorcraft FL-500S oil filter and see if the noise goes away,BTW think the Fram and K&N filter are made from cardboard inside,no metal frame inside. ZJDW1 said:^lol. I use the K&N filter with Mobile1 10-30.
I wholeheartedly agree with Z on this as the 5 weight will be thinner at startup and get into the nooks and crannies faster. I'm pretty sure Mobil has a 0-30 full synthetic as well...which is what I would run especially if you live in a climate that gets cold.ZSHO said:If you like using Mobil 1 then you should use 5w-30 labeled on your oil cap along with a Motorcraft FL-500S oil filter and see if the noise goes away,BTW think the Fram and K&N filter are made from cardboard inside,no metal frame inside. ZJDW1 said:^lol. I use the K&N filter with Mobile1 10-30.
You can never have too little viscosity at startup. That is where 80% of engine wear occurs. The thinner it is the faster it gets to the moving parts.JDW1 said:Derp, typo on the 10w, I do use 5-30 but I will def try the MC filter next time. Thanks guys. Also, I'm in Alabama so it doesn't get super cold, 0-30 may be a little much.
FoMoCoSHO said:Anybody ever heard of Alisyn synthetics?
Straight less than zero weight oil...
http://syntheticlubricants.aerospacelubricants.com/item/automotive-oem/prodrive-21/pn7041-1199?&plpver=1001&origin=compare&filter=0&CTypeID=2
SHOdded said:Used to be the mfr's would suggest running a heavier weight oil in summertime and a lighter oil in wintertime, for appropriate startup characteristics. Now it's the same oil year round. Oils and their performance characteristics have improved greatly over time, partly reflected in the SAE ratings. So I would take the mfr's guidance seriously for year-round performance. If you consider changing to another oil/weight, compare the characteristics to make sure that your new oil will meet or exceed the requirements, the "meets xxxx specs" being a starting point.
Although this is not as much of an issue anymore, in the past, when dino spec'd oil was the norm, people started using a full synth (usually Mobil 1) of the same weight. Unfortunately, the full-synth oil did not really behave even close to what the dino oil was expected to, and proved too thin for practical use (outside engine tolerances), causing oil leaks through seals. So if you were supposed to use 5W30 dino, you would have to use 5W40 full synth for comparable performance inside the engine.
I read on a different page it is claimed to be group IV, 100% PAO.ajpturbo said:FoMoCoSHO said:Anybody ever heard of Alisyn synthetics?
No i havent...seems gimiky....where is the total base number...thats the good stuff...
salsathe4th said:Did we ever figure out how to get rid of the rattle? Mine is quite loud and I just recently replaced the tensioner and belt (didn't change the noise). Im also changing the oil to AIMSOIL tomorrow to see if that will fix the issue. I'll try to take a video of the sound and post it here.
SHOdded said:Yeah, it may be timing chain stretch.
mine sounds the same as yours, sometimes even louder and longermarkssho said:Here's my start up rattle.
I'm wondering if it is the cam phasers, like was diagnosed in the F150's...
https://vimeo.com/163487698
Sent from my XT1094 using Tapatalk
