*** work in progress - not able to access the pdfs for some to verify years affected ***
continued in this post
12A04-S4: CERTAIN 2011-2014 MODEL YEAR VEHICLES EQUIPPED WITH SYNC AND MYFORD/MYLINCOLN TOUCH - APPLICATION PERFORMANCE UPGRADE
12B43: CERTAIN 2013 MODEL YEAR TAURUS VEHICLES - AIR CONDITIONING SYSTEM PERFORMANCE
12M02-S1: CERTAIN 2011-2014 MODEL YEAR VEHICLES EQUIPPED WITH SYNC AND MYFORD/MYLINCOLN TOUCH - WARRANTY EXTENSION COVERING ACCESSORY PROTOCOL INTERFACE MODULE (APIM) SOFTWARE AND HARDWARE
13-8-2: MYFORD TOUCH/MYLINCOLN TOUCH-NAVIGATION/VOICE RECOGNITION/CALL SOUND QUALITY/PHONE PAIRING/CLOCK/MEDIA/WIFI PASS CODE AND/OR SYSTEM PERFORMANCE
13-8-7: INTERMITTENT/INOPERATIVE INTEGRATED KEYHEAD TRANSMITTER (IKT)-BUILT ON 9/1/2011 AND THROUGH 12/1/2012
13-9-16: AWD - LEAK FROM PTU - BUILT ON OR BEFORE 1/25/2013
13-12-2: DIRT ACCUMULATION ON REAR DOOR SCUFF PLATES Pics here http://www.ecoboostperformanceforum.com/index.php/topic,7657.msg115967.html#msg115967
13T01: Demonstration/Delivery Hold 2013-2014 Model Year Edge, Explorer, And Taurus Vehicles Waterpump Weep Hole Blockage Product Enhancement
14-0023: HEADLINER DROPPING DOWN AND/OR LOOSE AT REAR WINDOW GLASS
14-0032: AWD-LEAK FROM PTU-BUILT ON OR BEFORE 12-11-2013
14-0037: GLOBAL POSITIONING SATELLITE MODULE (GPSM) NAVIGATION DISPLAY OFFSET OR INCORRECT POSITION BUILT ON OR BEFORE 1/6/2014
14-0050: 4.2 INCH DISPLAY RADIO-UP/DOWN ARROW BUTTONS INOPERATIVE
14-0057: ALL WHEEL DRIVE-FLUID LEAK FROM REAR DIFFERENTIAL VENT CAP-TEMPERATURES BELOW 0 DEGREES C (32 DEGREES F)
14-0060: POLICE INTERCEPTOR-ERRATIC OPERATION OF CLIMATE CONTROL BLOWER MOTOR-LOSS OF COMMUNICATION WITH HVAC MODULE
14-0091: 3.5L GTDI ENGINE - RAW FUEL- TYPE ODOR NEAR INTAKE MANIFOLD-BUILT ON OR BEFORE 2-20-2014
14-0102: ILLUMINATED MIL WITH DTC P0420 AND/OR P0430-BUILT ON OR BEFORE 4/25/2014
14-0105: 3.5L GTDI DIAGNOSTIC TROUBLE CODE (DTC) P0087-BUILT ON OR BEFORE 6/1/2014
14-0109: RIGHT HAND MULTIMEDIA DISPLAY AREA MISSING THE COMPASS AND TURN BY TURN DISPLAY-BUILT ON OR BEFORE 1/25/2014
14-0113: 3.5L GTDI-EXCESSIVE OIL CONSUMPTION AND /OR SMOKE FROM THE EXHAUST AT IDLE DURING NORMAL ENGINE OPERATING TEMPERATURE-ALUMINUM VALVE COVER
14-0123: HD RADIO INOPERATIVE-DIAGNOSTIC TROUBLE CODE (DTC) U3000:96
14-0130: EXHAUST ODOR IN VEHICLE
14-0132: EASY FUEL CAPLESS-CONCERNS WITH FUEL NOZZLE INSERTION OR REMOVAL
14-0169: NO AUDIO OUTPUT AFTER STARTING
14-0175: MY FORD TOUCH/MY LINCOLN TOUCH-AMBIENT LIGHTING DEFAULTS TO WHITE OR ICE-BLUE AFTER CYCLING IGNITION SWITCH
14-0186: TING/POP/CLICK NOISE-FRONT HALFSHAFT
14-0196: 3.5L GTDI-EXCESSIVE OIL CONSUMPTION AND/OR SMOKE FROM THE EXHAUST AT IDLE DURING NORMAL ENGINE OPERATING TEMPERATURE-ALUMINUM VALVE COVER
14-0198: EXHAUST – SULFUR ODOR AFTER HARD ACCELERATION
14-0223: 2.0L GTDI – LACK OF POWER – DTC P2111, P2101 AND/OR P2112 – AMBIENT TEMPERATURES BELOW 0 DEGREES CELSIUS (32 DEGREES FAHRENHEIT) BUILT ON OR BEFORE 10/5/2014
14-0231: MYFORD TOUCH – concerns with navigation, voice recognition, call sound quality, phone pairing, clock, media, WiFi pass code entry, rear view camera guidelines, no Russian language package and/or poor system performance.
14-0234: CHATTER OR GRINDING NOISE WHEN POWER FOLDING THE EXTERIOR REAR VIEW MIRRORS – BUILT ON OR BEFORE 11/1/2014
14S08/14R01/14V285000: Water Intrusion may cause License Plate Lamp Fire
14S10/14V393/14V393000: Halfshaft Disengagement/Loss of Drive/Roll Away MORE ...
15S02: FIELD SERVICE ACTION - recall involves 2010 to 2013 model years of the Ford Taurus and Lincoln MKS. Ford says a door latch spring can become unseated, allowing the door to unlatch in a side-impact crash. The company says it knows of no injuries from the problem. Dealers will inspect the latches and replace door handles if needed. MORE ... BiGMaC: More details on 15S02
15-0003: 3.5L GTDI – FUEL ODOR FROM ENGINE OIL AND/OR ENGINE OIL LEVEL OVERFULL
15-0013: DOOR AJAR LAMP REMAINS ILLUMINATED WITH DOORS CLOSED
15-0047: SHIFT TO PARK OR TRANSMISSION NOT IN PARK MESSAGE – DISCHARGED BATTERY DUE TO SHIFT TO PARK LIGHT ON / UNABLE TO REMOVE IKT (supersedes 14-0209)
15-0056: AWD – LEAK FROM PTU – BUILT ON OR BEFORE 12/11/2013
15-0086: 3.5L GTDI – EXCESSIVE OIL CONSUMPTION AND/OR SMOKE FROM THE EXHAUST AT IDLE DURING NORMAL ENGINE OPERATING TEMPERATURE – ALUMINUM VALVE COVER
