I know this has been discussed but I can't find the thread. Since I now run the 93 octane LMS tune, of course the fans run ALL THE TIME! I am sick of it. That is causing me to want to downgrade the loaded tune to the 91 4x+.
My question
1. Has LMS changed the set point to trigger the fans to run as much?
2. What temp thermostat are you 93 tune guys running?
3. Is there any benefit or trade off is I install the 160 thermostat and keep the tune?
4. Is LMS targeting an unrealistic engine temp, therefore forcing fans almost into an on/off mode small donkey-like animal opposed to modulating mode.
My car never runs above 190 degrees. I currently have the 170 t-stat installed. On a cold start, the fans come on at roughly 140 degrees. Then anything above 170, they are at full blast. Including when running down the highway on a cold day.
My question
