Cross Country Towing SHO
polskifacet
Dudes,
Given Insurance sucks and scarred my SHO with structural damage when there was 0 rack time means I have to pull a ~3000 lbs trailer from Chicago to Phoenix with it. I already installed a CURT class 3 hitch, bought original PP shocks , and also bought the airlift 1000 airbags to help with sagging. I'm in the middle installing a Prodigy 2 brake controller and am trying to find the right brake wire to feed into the brake controller, any tips would be great.
polskifacet said:
SM105K said:
I have no input on the trailier, but why are you coming to Phoenix?
Bought a house in Gilbert
Nice.  You are moving here at the right time.  You escape the heat of our summer, and bitter cold of Chicago.
Just make sure Brad makes a revision to your 93 octane fuel tune because we only have 91 out here.  The good thing is, he has a pretty good data collection from me with the extreme heat and that will help you as well.  It will be nice to have another AJPTurbo tuned SHO lurking the valley.
When you get settled here, there is a huge car show that happens at the Scottsdale Pavilions every Saturday from about 4 pm to 9 pm.  Maybe we could meet up.
I think I found the correct wire thats at the plug that attaches to the brake pedal. Violet White wire gives +12 volts when you press the brakes.
It does look like the Violet/white wire is for the BPP Brake pedal position switch! Diagram for the APP Below if needed. Best of luck with the new Home! Z  :)
