Datalogging question
Ryan02Stang
I'm heading to the drag strip tonight to get some datalogs for my Unleashed tune.  My MKS right now has a 3 bar, and an Unleashed tune, but it otherwise stock.  I've got the SCT software installed on my laptop, Torrie sent me a datalogging file, and I've hooked everything up in the car to make sure it all works and it does.
Is there anything else I need to do other than load Torrie's file in the SCT program, hit record, and make some runs?  Do I just save the CSV files and then send them over to Torrie for a revision?
Appreciate the input!
That's correct.
When you hit stop on a data log, just save each one. (Be sure to make a good name for each run to find easily later.)
I would normally send Torrie two or three logs for each set just to eliminate as many variables as possible.
That is all you need to do. To make things easy while at the track I make a folder for the night and save 1 file in there to start with that way every time I click save it goes to that folder right away.
So I dont want to pay a ton of attention to it I tend to save with names like "11111", "22222", etc until I get home. Then I put my slips in time order and match them to the log files for each run.
