SCT might have boned me indirectly
TopherSho said:
mattr66 said:
The 1635 is internal voltage reference bad... May be the reason the pcm bricked in the first place...
Sent from my motorola edge plus using Tapatalk
hmm got a link?
I found this on DTC which logically sounds more likely since it is a muffed write to the ecu/pcm
https://www.dtcdecode.com/Ford/P1635
Make:Ford
Code:P1635
Definition:Tire/Axle Ratio Out Of Acceptable Range
Description:This DTC sets when the tire and axle information contained in the vehicle identification (VID) block does not match the vehicle hardware.
Cause:Incorrect tire size,  Incorrect axle ratio, Incorrect VID configuration parameters
Diagnosis: Using the scan tool, view the tire and axle parameters within the VID. They must match the vehicle hardware.
Component: PCM
Yeah it's crazy how that code is different between mfgers.  On most vehicles it is the 5v bus being out of whack.
mattr66 said:
hmm got a link?
Make:Ford
Code:P1635
Component: PCM
WERE FORD!  WE DO IT ALL DIFFERENT! MAKES BETTER!          /headesk/  :D  :)
TopherSho said:
hmm got a link?
Make:Ford
Code:P1635
Component: PCM
I am betting the p1635 is a result of the PP 3.15 axel ratio being programed in instead of the non-pp 2.77 .. fingers crossed.  HOPEFULLY the bad axel ratio is what is disabling the ACC/Collision warning system
So. The initial gearhead tune programmed a wrong ratio and it stuck in the system ?
Macgyver said:
TopherSho said:
hmm got a link?
Make:Ford
Code:P1635
Component: PCM
It was not throwing a CEL while the GH tune was on,  but when I reverted back to stock from the GH tune it all went sideways on the next restart.  SCT rebuilt the stock image, and and applied it with the handheld, Ford laid down a fresh image using IDS ... no luck either way.
But from reading a number of articles it appears you can 'edit' that value using Ford diagnostic tools .. so i am super crossing my fingers that if the ford techs are decent enough to see the same links and try the fix, that the other issues will self resolve as i hope/suspect the ACC and Collision systems can't work if they have no idea what the speed of the care is.. and are simply faulting on boot and seeing the axel ratio error.
Macgyver said:
TopherSho said:
hmm got a link?
Make:Ford
Code:P1635
Component: PCM
No the vid block was more than likely corrupted on the flash.
At this point I am unsure .. but why would my car operate normally if the value was missing after the flash to the GH tune?  Or are you referring the flash back to stock?
The flashing process in general corrupted the vid block I think
SCT update ---------------------
Date: Wed, Mar 24, 2021 at 8:21 AM
Subject: RE: Flash to stock corrupts ECU with new 4x firmware
To: Topher Mc'toperton <######@gmail.com>
Cc: chris.beeck@broadcom.com <######@broadcom.com>
The firmware Jose loaded to the device will allow us to resolve the P1639 & P163F code remotely if they were to occur again. Make sure the device firmware version is on 1.1.1.7 build 21 SHO before attempting another flash with the SCT device.
P1000 is completely normal after a flash and normally clears after driving a certain amount of miles. Depending on the vehicle.
P1635 - Tire/Axle Out of Acceptable Range [Ford/ISO 14229]
^^ P1635 doesn’t make sense, especially after an IDS flash from Ford, and I’ve never seen this code occur after IDS personally.
ACC & Collision Disabled warnings on the dash might be cleared through a hard reset of the ECU. (Physically disconnect and reconnect the ECU from the harness after disconnecting the battery)
Thanks,
SCT Technical Support
Reading tea leaves here .. but there IS a special 4x SCT tuner firmware for 2010 and 2011 SHO's.  My 4x tuner did NOT have the 'SHO' tag on the previous firmware when I was tuning with brad.  getting interesting..
my gut says old style tunes did not need certain access rights to some regions/tables.. the GH tune needed them.  my tuner broke with GH as it was old when i used it.. but it somehow tuned the car without triggering the axel ratio error and or ACC/collision error.
on stock reversion it went sideways..
Ford has the car,  well see what happens from here.
Ford has called --
They believe it has been resolved.
Phone rep said and i quote --
They reset the ABS by 'reinitializing'
ACC needed to be put into relearn
No notes were taken on the P1635 .. or its resolution.
I will scan it when I get there .. the p1000 may still be present , but if it is it ''''should'''' clear on its own as the system collects sensor data by driving and getting a baseline.
I plan on driving it over to Autozone and having them scan for codes since the 4x can miss some things
fingers crossed....
This will close the topic.  After 4 cycles of start and drive to 20 minutes followed by a full cool down to ambient temp p1000 has cleared.
All issues fully resolved.
For anyone else who ends up in this boat ..
Do not hard reset the ecu yourself you will get additional codes.  if after a return to stock wiht a SCT 4x you get --
--ACC disabled > 'malfunction' on dash
--collision disabled  > 'malfunction' on dash
--Running rich by 10% but no codes
--p1000 DTC OBD II Monitor Testing Not Complete
--p1639 DTC    Vehicle ID Block Corrupted, Not Programmed
--p163f DTC  Transmission ID Block Corrupted, Not Programmed
--*possibly a p1635
Call SCT emergency line.
Get the ''SHO'' SCT firmware updates as they mention in my previous post with a copy of their email,  and have SCT help you return to stock
once the p1639, p163f go away with the SCT fix .. if you have additional issues go to ford and have the affected systems reset and or set to adaptive learn.
cheers
