No just their landing coordinates so I could pick up my cousin.ajpturbo said:It was an update from the mothership
On the SYNC update screen?BiGMaC said:Still.... There must be a way. My '13 SHO has automatically downloaded some updates on startup. When it did that on two occasions (it told me that it was doing so on the big center screen)... All the info from the center screen was transferred during that time to the right LED screen beside the speedometer... Just saying, no clue as to how.
It sent fuel pressure(very low), IAT1,2,CAC, coolant temp, trans temp IIRC.ecoboostsho said:Ha! Assuming you are referring to FoMoCoSHO's comment - Well I could tell you what the data was if I happened to catch it in process - which would be very difficult to do since it sounds like it doesn't happen on a regular basis. You'd have to be sitting there watching the CAN bus when it happened. It would be interesting to see what is going on if it truly is sending data on its own.
m3dragon said:BiGMaC said:Still.... There must be a way. My '13 SHO has automatically downloaded some updates on startup. When it did that on two occasions (it told me that it was doing so on the big center screen)... All the info from the center screen was transferred during that time to the right LED screen beside the speedometer... Just saying, no clue as to how.
Probably need access to the code to display items. Drive split, oil temp, boost pressure, and volts would be 4 small gauges I would love to have on the right side. The data is there, just need to program the display in "display mode".
Anyone friends with the tuners like Liverinous or Diablo?????
