Haven't datalogged yet. I wanted to install my hotpipes but temp dropped 20 degrees and now its 35 out, supposed to go upto 50 on Sunday so I might wait until then and also do an oil change at the same time.
I think I'm going to chop into that hose assembly I bought and try to slip this fitting in with a heatgun and see how it goes..... chopped that hard plastic pipe, my TEE is like 6AN the hard plastic hose is 11mm ID, I have 11mm hose clamp which is a hair too small to fit so I need like a 12 or 13mm, my 14mm hose clamp is a hair too big. Is this line under boost pressure or just vacuum? Looks like I'm running to the autoparts store
