Dyno for PPE down pipes
FoMoCoSHO said:
So you think 6400 is safe AJP?
It doesnt seem unhealthy...fuel pressure would be fine at 18-20 psi boost because the high pressure pump has plenty of rpm.
But i would guess the turbo shaft speed would be incredible and im guessing its getting way out of its efficiency range....maybe if you were only running 12-14 psi it might be ok to rev to 6400 but a dyno curve would maybe be the best indicator...at 16 psi the amount of wastegate duty cycle required to hold that boost starts to really take off...mine starts to head to 80% fast...thats kind of my own self imposed limit
When i was at the dyno tuning i felt like i liked the monster boost better but only revving to 6k rather than less boost and 6500.
And the fact that the turbine wheels are something ridiculous like 38mm its just seems counter productive to rev the **** out of this motor...seems to me that this motor was made to be a mid and low range monster
EcoPowerParts said:
You lose all power by 5500 RPM so kind of pointless to shift that high....
The dyno for the downpipes showed a pretty decent curve up top (I was surprised)
Shift calculators all seem to show more power winding out than short shifting. (PP equipped cars only)
I want to take a couple logs graphing with an accelerometer with RPM, gear, and FRP for comparison. That should be a better indicator than shift point analyzers and random dyno curves that aren't mine. If I can shift higher without breaking anything or slowing down, that cam will be moving faster in the next gear which can only help FRP after the shift.
Maybe it was just the bigger turbos but all my graphs and all I've seen with higher HP cars the power drops at 5500ish like a STONE.
That's why the dyno results in this thread and comments are confusing. The bigger turbo cars surely like to rev better than stock but looking at page one the car seemed to make power all the way up.
And you are correct, most dyno sheets I look at the power is definitely falling off which is why I was surprised at the on paper results. The gearing and torque multiplication of the pp cars seem to overcome the power drop off. The  suggested points of the 2.77 cars are drastically different.
I think most of the power falling off at 5500+ is due to falling boost...most data logs ive seen the boost tapers off sometimes because thats whats being commanded and sometimes because the boost solenoid is not adding enough wastegate to achieve target boost...when i hold boost to redline my power looked pretty good at 6000 rpm...fomo has my dyno sheet if he wants to post it...i have phone issues
But even if the valve train and engine are ok to run higher the turbo will be the choke point id say above 6k and i would worry about the shaft speed of those 400$ stock garrets
And at high boost and high rpm the stresses on the rotataing parts increases exponentially with rpm due to piston speed..i just wouldnt be interested in running the car ragged
Following this as well.
Interested in catted downpipes.  Anyone know if it will make my Corsa noticeably louder?  Trying to avoid the exhaust being louder.
It certainly will make it sound raspier unless you install a resonator in place.
The beauty of the Corsa cat back exhaust is that emits zero drone to the cabin which is a Big Plus IMO. Z
I know catless will make them raspy. From all the vids I have scene and heard on YouTube with catted downpipes and the Corsa, there is no rasp.  However, can't tell from the vids how loud it is in person which is want I'm worried about.
Thanks for the info though.
