BiGMaC said:It's also frankly an attitude thing... like having confidence because your underwear is clean without holes.![]()
Needmoreboost said:Thanks for sharing. Did you leave the third shared cat on??
The dyno does a drivetrain loss evaluation by doing 0-60 pulls and coasting down68_GT said:good info all kind of how I expected. Once your're tuneed I'd like to see an overlay of the stock pipes versus catted, and non catted if you're willing to put the stocjers back on for a pull.
How did you get crank hp on a dyno ?
4DRHTRD said:The dyno does a drivetrain loss evaluation by doing 0-60 pulls and coasting down68_GT said:good info all kind of how I expected. Once your're tuneed I'd like to see an overlay of the stock pipes versus catted, and non catted if you're willing to put the stocjers back on for a pull.
The dyno treats torque #'s wrong if looking at to the wheel calculations, they're way off - the line is right, number is wrong. I would assume that he is 20HP over published numbers (underrated) compared to quoted 365.68_GT said:4DRHTRD said:The dyno does a drivetrain loss evaluation by doing 0-60 pulls and coasting down68_GT said:good info all kind of how I expected. Once your're tuneed I'd like to see an overlay of the stock pipes versus catted, and non catted if you're willing to put the stocjers back on for a pull.
interesting never heard of that, and my guess is that's becasue I don't understand why you would dyno that way ? unless your're trying to do a comparrison at the crank to what Ford reports the stock power output to be ? What is the stock power 365hp ? that would be a 40hp gain for the non catted pipes if the correction is accurate ?!
Absolutely… the delta is the important data… how do the line's positions move in the comparison to each other with changes made. The car is much different to drive on the low end as described…earlier spooling and hp/TQ spike up.4DRHTRD said:The dyno treats torque #'s wrong if looking at to the wheel calculations, they're way off - the line is right, number is wrong. I would assume that he is 20HP over published numbers (underrated) compared to quoted 365.68_GT said:4DRHTRD said:The dyno does a drivetrain loss evaluation by doing 0-60 pulls and coasting down68_GT said:good info all kind of how I expected. Once your're tuneed I'd like to see an overlay of the stock pipes versus catted, and non catted if you're willing to put the stocjers back on for a pull.
The key is the comparison #'s not the my dyno vs your dyno #'s scenario. I wanted to get the differences between stock, catted and catless. We'll be going back with Tom's car to compare stock, catted and catless tuned as well.
4DRHTRD said:We'll be going back with Tom's car to compare stock, catted and catless tuned as well.
black99lightning said:no dyno numbers but I picked went from a best of 13.12 to a new best of 12.98 with the offroad DP's. I think in stellar weather, 40-50 degrees, I could possibly pick up another tenth.
FoMoCoSHO said:No problem BigMac...
I am a little disappointed with the catted DP #'s.
Yes, in all cases...Needmoreboost said:Thanks for sharing. Did you leave the third shared cat on??
