Dyno Results
arrivalblue's 2013 MKS
K&N dropin filter only
I guess it’s acting as it should ...in theory you should not see any power increase from an intake since the stock tune is targeting a torque value . So you would have to monitor boost and the stock tune would run less boost and see the same power
The car knows the torque so if you are making more because the hardware is more efficient then the ecu would lower the boost targets
Sounds like Nissan Jukes. You can bolt on everything that should make more power. Sans a new Turbo. The ECU nerfs it. Thats why we tune.
5ohSHO  2018 PP-SHO
405hp/447tq.
2018 SHO Velvet Burgundy w/PP. MDesign CAI, 3 bar map, MSD coils, .30 plugs, 160 t-stat, Thunderstorm cat-less dp's, Corsa cat-back, Alky Control meth injection, EPP Hot Pipes, Dyno tune, H&R springs and Advanti Hybris wheels.
405hp/447tq.
StealBlueSHO's 2016 PP SHO
Uncorrected
(Not yet tuned for the turbos/hotpipes, running a base tune only)
https://youtu.be/b1xjQSkiGmQ
Follow the build thread here:
https://www.ecoboostperformanceforum.com/index.php?topic=9894
2016 Taurus SHO PP, Gearhead Tuned, XDI HPFP, Gearhead Intercooler, Corsa Exhaust, HR Springs, Airaid Intake, EPP Hotpipes, 160Tstat, 3BAR Map, LMS Catch Can, Upgraded Torque Mounts, SP-542's, Gearhead Turbo Upgrades and EPP Catted Downpipes
AJP 93+meth 58 deg 77% humidity with the DA at 4020' on 1/3 of the meth LMS was using. on a mustang dyno with all the same mods as a few post back
I would MOST definitely work with AJP again he is an awesome communicator and takes the time to make it right. NOT a one hit wonder and you will have to do your part to get logs to him.
Nice numbers, can't wait to see what you do at the track....
E30 tune by AJP 3700 feet DA at 70*. Run number one was my meth tune file loaded (for comparison)  Run 2 and 3 where the E30 Tune
Very nice!  Is the meth tune with 93 or is it e30+ meth?
ddlopes 2013 SHO with Perf Pkg:
Dyno results on Boostane Professional
index.php
vs E30
index.php
Setup:
EcoPower Parts dual CAI, 3 bar, PPE catted down pipe, SCT X4, 170 degree thermostat, SNOW PERFORMANCE methanol stage 3 with ProMeth staineless steel braided lines, AeroForce gauges, Hot pipes, custom boost activated cutout xpipe, tial bov, Tial Wastegate mod, GH intercooler, MSD coils, AFE throttle spacer, UPR catch can, Rovos Durban wheels, AJP tuned to 389hp and 503trq on mustang dyno
Jordan's 2013 SHO
AJPturbo tuned:
Gearhead tuned:
AJPTURBO AND GEARHEAD TUNED - XDI35 HPFP, Gearhead Intercooler, Anthony Dicunzolo trans mounts, J2 Dual Intake, PPE catless downpipes, MSD coils, full exhaust, Ebay compressor wheels
