E30 in winter
My last log on my E30 tune was in March with ambient temp of 45° I stopped running the E30 tune in the winter because I'm having fuel pressure issues when temperatures are cold,don't know if it's the tune or what
Does anyone run e30 in cold weather?
I was told WMI would fix my issues, il leave 2 back to back data logs from that day if anyone wants to take a look and let me know what you think.
It seems normal for a E30 tune with a stock HPFP to struggle while it is cold outside.  Most guys only run the E30 tunes while it is warm.  I will log my SHO next week to see what happens with my E30 tune in 50 to 60 degree weather.
I run e30 temperatures allowing. Anything under 40 degrees Fahrenheit I just run 93 out of safety concerns but 40 around 55 degrees I'll run my 14 psi e30 tune with heavy throttle control. Anything above that I'll run my finalized 15 psi e30 tune. Anything lower than those temperatures for my specific tunes. I am not comfortable with doing. Once you get down to below freezing even on 93 with a low boost (13 psi) you can still be draining the fuel system. At 10 degrees ambient on 93 (30 ish degrees iat2) I was dipping fuel pressure to some not so safe areas between shifts. So it's heavily dependant on how far you want to push your car and how much throttle control your tuner puts in place. Torrie has been known to push things very hard so I'd be careful and look at the data closely
So in your case, 55 degrees and above you run a lower boost E30 tune. Pretty sure I am falling in that boat.  On your 93 octane tune while under 40 degrees are you seeing considerably more knock vs say 75 to 80 degrees?
40-55 I've been running my 14psi e30 tune. Anything above I'll run my 15 psi finalized version. I see no knock other than a random .5 here and there no matter the temperature. I'm set up to add timing if the knock sensors are happy so I never end up actually pulling any.
I haven't driven my car in the "cold" here yet.  The lowest the car will probably see is 45 ish.  So it will be interesting to see what the logs say.
Thanks for all the input. I'll  have to run a data log on the 93 tune and see how fuel pressure is and go from there.
If I'm having issues  with 93 tune in the winter maybe il get him to make it a more conservative  tune
Helps to play with the 93 fuel.  Brand quality apparently is different in different areas.  Shell may be best, or Sunoco, or Exxon.  Worth a shot.
I run Ajp E30 tune almost year round in CO and my fuel pressure stays rock solid. NO throttle control BUT i have the wastegate mod and it helps tremendously. stabilizes FRP despite the weather etc.
also my load range isn’t quite as high as you sea level guys.
i do make it a point to watch FRP when it gets real cold. but it always stays north of 1700psi so rally nothing to worry about.
I just want to add a little tidbit of info here as I think it's very relevant. Your fuel pressure is going to be heavily dependent on a few things. Boost, Temperature and Elevation. Lower boost isn't going to be as demanding. Lower temperature is going to be more demanding. Higher elevation is going to be less demanding. Without this information it's hard to compare apples to apples.
