E30 worth it?
Ive had unleashed 3bar 93 tune for a few months with a few revisions on my flex feels great but was thinking about going with a E30 tune I have plenty of e85 stations near me. The extra $99 for E30 tune worth the difference in performance?
2013 Ford Flex Ecoboost
H&R lowering springs
Sctx4 4bar map(Torrie tune)
Yes!!!! I went from e20 to e30, lowered my boost to 14psi and went faster with a better 60ft time... do it and don't look back
Ran a 12.491 with a 1.810 on e20 15psi  40 degree weather(unleashed)
Ran a 12.433 with a 1.798 60ft on e30 with 14psi in 65degree weather with (ajp tuning) it even closes throttle in between gears to stop the boost spikes
Wow that's some great numbers! I would love to get my flex into the 12's
Sent from my Pixel using Tapatalk
Are you testing the e85 in our area? Is it actually 85%
Yes I am, over winter it was 70% have not checked since
ChrisxHowe said:
Ok great
I just realized you are in Lancaster area, I think we talked before. Sheetz has been putting e85 in a bunch of their stations. I use prospect road sheetz, only 1 minute from my house. But I heard there are other sheetz stations putting e85 in. I used to use mollys in Manheim, but they took it out. Then was using wo-go in greenfield, but now sheetz is way closer.
Yea i have seen a few Sheetz with it and I work almost right beside the Wo-Go I worked there about 5 years ago that's were I'll most likely get it. Sheetz on Manheim pike have it also
f8tlSHO said:
ChrisxHowe said:
Ok great
I am in the Reading Area. Lancaster side. I will have to check the stations near me and see what they have.
StealBlueSho said:
https://getethanol.com/ethanol-finder/
Fairly accurate... you can always call the gas station to confirm.
That's a great site! Much better then the others I found
f8tlSHO said:
ChrisxHowe said:
Ok great
There's a lot of sheetz out your way....
SilvererSHO said:
f8tlSHO said:
ChrisxHowe said:
Ok great
There are convenience stores like every mile around here..
No.  E30 is 30% Ethanol, Ethanol has less power per liter than gasoline.  Pure gas will always give you better mileage than a blend.
