arrivalblue
How many of you are running e85 on your SHO or MKS?? If so what did you have to do to run it? And was it worth it??
Who's your tuner ? Due setup your signature so we can assist you better! Thanks . Zarrivalblue said:Yea for sure! I’m sure he will know but wanted to get some info so I’m a little informed when talking to him lol.
StinkinLinkin13 said:I was wondering this as well... Seeing as on my gas fill it readse30 e85. I thought flex fuel had different orings, seals etc...
I would make certain that you purchase a new MDesign intake Directly through them and NOT used as the warranty is NOT Transferable IIRC! Zarrivalblue said:I just ordered it last week. I’ll be using Torrie from unleashed. I like the ability to data log. I’ll update signature but so far it’ll be a thermostat, new plugs, drop in filter, and 3 bar sensor. I’m looking into other stuff though including the mdesign CAI the numbers seem very good and dyno backed
AJP turbo said:Having the hardware or and the logic in the calibration to be flex fuel capable are 2 different things...Most of the new Fords have the hardware to run higher ethanol content. The reason your filler neck says to use only E0-E15 is mostly due to the fact that the logic is not there to handle fuel switching AND the capacity is not really there...You can run E85 but there will be a boost compromise......As Ethanol content goes up then boost needs to come down.
StinkinLinkin13 said:AJP turbo said:Having the hardware or and the logic in the calibration to be flex fuel capable are 2 different things...Most of the new Fords have the hardware to run higher ethanol content. The reason your filler neck says to use only E0-E15 is mostly due to the fact that the logic is not there to handle fuel switching AND the capacity is not really there...You can run E85 but there will be a boost compromise......As Ethanol content goes up then boost needs to come down.
Ok. That's what I was wondering. Most hardware is in place so basically just need the custom tune for it.
arrivalblue said:By limitations though would it not be worth it without fuel system upgrades? I mean would a limited E85 tune be better then a 93?octane tune?
Not necessarily.arrivalblue said:Lower boost less power though right? or not always?
So many variables....Macgyver said:Just an informative question for us all.
Long term engine life. What is better ? Does it matter ?
Lower Boost and More spark using higher Corn content then you get more fuels in your oil? etc.
Higher Boost and less spark using less corn in your fuel etc.
FoMoCoSHO said:So many variables....Macgyver said:Just an informative question for us all.
The safer way of making power? Not sure but I do know I keep my turbos in their happy place, just a couple PSI over stock and the both cars haul a$$. 15 PSI available anywhere anytime with 26-28 degrees just feels sick. No more running out of breath at high RPM, just pulls endlessly well into felony territory. Car doesn't pull timing in the summer because IAT compensations come on line much later (140 IAT2) and probably can be turned off completely with the full corn.
More advance equals higher volumetric efficiency and E85's ability to run at Lambda 1 to higher RPMs and loads increase that further, more bang for less bucks at the pump.
I think corn is a better fuel for the Ecoboost not just for performance but it is markedly cleaner than pump. No sooty tips. I suspect that property may help longevity greatly. I just got pics of my valves and I'm curious to see what happens moving forward. Too bad For Ford cheaped out on the certification and pump. My plan is to use as much corn as possible.
I just changed oil at at 10K interval with 5k of full corn....Oops?
Faint hint of fuel, no change on the stick, and nothing out of the ordinary visually.
Going forward I plan to change every 5K and get some samples analyzed.
Thinking about full E85 and meth after ESP runs out.
StealBlueSho said:FoMoCoSHO said:So many variables....Macgyver said:Just an informative question for us all.
Is there a DMR to measure the temperature in the cylinder? Or have you measured EGTs? I am curious at 1 lambda under wot what the temps are? Part of the reason to running rich at load is to help keep things cool as the extra fuel carries away some the heat out of chamber... helping keep the pistons cooler...
I know that Ethanol helps cool things just by virtual of being alcohol... not sure where the offset is?
