DJE624 said:SwampRat said:I'm trying to figure a way to better seal the AirAid to the Underside of the Hood and Ducting to the Box itself .
That would be the stock box which is sealed and takes its air from under the front of the hood. Just trim the hood molding, throw in a K&N panel and you have the best set up.
I still think if you could get a larger opening capable of a higher CFM flow rate , that drawing in fresh air AWAY from the grill or engine compartment to a filter with MORE surface area it would be a better option . IMHO
