Emmission testing
I apologize for bringing this up again,my new PPE DP should be here soon and emmissions testing will be here soon also,just wanted to clarify that the best option would be returning to stock,for states that are strict and reqire readiness testing,in regards to catted DP.Thank you all and have a safe Memorial Day.
Should have no problem passing emissions with catted DP from PPE.  Just be sure to drive a couple of hundred miles after the installation to reset the readiness monitors before going in for testing.
From the 2013 SHO Owner's Manual (pg 198):
Readiness for Inspection/Maintenance (I/M) Testing
Some state, provincial and local governments may have
Inspection/Maintenance (I/M) programs to inspect the emission control
equipment on your vehicle. Failure to pass this inspection could prevent
you from getting a vehicle registration.
If the service engine soon indicator is on or the bulb does not
work, the vehicle may need to be serviced. See On-board
Diagnostics (OBD-II) in this chapter.
Your vehicle may not pass the I/M test if the service engine soon
indicator is on or not working properly (bulb is burned out), or if the
OBD-II system has determined that some of the emission control systems
have not been properly checked. In this case, the vehicle is considered
not ready for I/M testing.
If the vehicle’s engine or transmission has just been serviced, or the
battery has recently run down or been replaced, the OBD-II system may
indicate that the vehicle is not ready for I/M testing. To determine if the
vehicle is ready for I/M testing, turn the ignition key to the on position
for 15 seconds without cranking the engine. If the service engine soon
indicator blinks eight times, it means that the vehicle is not ready for I/M
testing; if the service engine soon indicator stays on solid, it means that
the vehicle is ready for I/M testing.
The OBD-II system is designed to check the emission control system
during normal driving. A complete check may take several days. If the
vehicle is not ready for I/M testing, the following driving cycle consisting
of mixed city and highway driving may be performed:
15 minutes of steady driving on an expressway or highway followed by
20 minutes of stop-and-go driving with at least four 30-second idle periods.
Allow the vehicle to sit for at least eight hours without starting the engine.
Then, start the engine and complete the above driving cycle. The engine
must warm up to its normal operating temperature. Once the engine is
started, do not turn off the engine until the above driving cycle is
complete. If the vehicle is still not ready for I/M testing, the above driving
cycle will have to be repeated.
I live in PA and have same checks as you. My PPE catted downpipes passed last Friday.
Sent from my mobile, I think.
i live in MO & in st louis same readiness check & like storm my catted PPE's passed emissions test no problem 2 weeks ago.
mikev
I returned to stock, achieved readiness and passed with my PPE catted, I am pretty sure returning to stock is not necessary but I'm not absolutely sure.
I haven't heard of anyone failing except for a guy that had a bad injector that flooded the cat with gas. That doesn't count though :)
