Engine oil drain plug
BlueSHO
Is the engine oil drain plug 12x1.75? I'm seeing some say 12x1.50.. Thx
Sent from my SM-G950U using Tapatalk
It should be Ford Part No - 9L8Z-6730.  Z
Thread Size- M12-1.75- Gasket or Seal  (SAE/Metric)15 mm.
https://parts.levittownfordparts.com/oem-parts/ford-drain-plug-9l8z6730a
I changed my drain plug to the Fumoto Drain Valve...I like it a lot, but it does take a lot longer to completely drain the oil.  But sure makes changing oil easier and eliminates a chance of stripping the the oil pan threads.
I've been debating doing this myself. I have one on my truck and LOVE it, (Truck takes 4 gallons of oil so it's a long oil change regardless) but I've never had a fumoto on an angled oil pan before.
Does it still shoot the oil back like the regular plug?
They make 2 different valves, an angled one and one with a nipple that you can put a hose on to direct the flow. I have the angled and it doesn't shoot the oil as far as removing the plug.
