F-150 EcoBoost Issues - CAC, Spark Plug, etc
This learning stemmed from my ecoboost f150 ownership experience. I also own a 13 SHO, and that was why I was looking into why the transverse engine application is so much better than the longitudinal in the F150. As i dug in on the f150 ecoboost forum, i got all of the info as they had dealt with it since the introduction. All experience and research shows that through all of the TSBs ford had, none were effective in stopping the condensate from building and blowing out spark. Do your research and look at 13 and 14s... They still have the stutter. Heck, my 13 sho had the stutter too. I drilled the werp hole and installed new sp534 plugs and not an issue since... And my intercooler drains nicely now. There are several ecoboost f150s here at work and when I ask about these issues, they explain how they have it too. None of them get on forums to understand though.
There is also a blown engine thread out there that tracks the ecoboost f150 engine failure and looks at what caused the engine to let go. Root cause is condensate. It has been that way for years now. No fix other than weep hole and new plugs. Those that have done that have never had the stutter ever again. The performance cones back, and no ill effects. Owners have put many miles on this and no problem. I have put a ton of miles on my SHO since doing the same and no problems at all.
I need to talk to the engineers at ford....i cant believe we are finally about to get resolution and closure on this...im about to get paid based on the intel im about to give them...they will be relieved to put  this all  behind them and allow the millions of ecoboost f150 owners to enjoy their trucks again
And im also going to call the BBB and notify them that ford is knowingly selling 2016-2017 trucks that still have the issue since there is no fix from them...thats bull crap
Remember, Ford can't do the weep hole themselves because the EPA would be on them for the oil and water mixture released on the ground.
I drilled my intercooler and never looked back.  No reason not to and I had three instances of water ingestion and don't want to grenade a cylinder. First video shows water that came out once drilled.  Second video is a test I did to see if I had a boost drop afterwards with test runs and boost gauge.  5 minutes of time will solve a major problem.  No logical reason not to unless someone is so worried about putting a couple drops of oil on the road per thousand miles.
https://youtu.be/QXP1KBXSny8
https://youtu.be/FFSQT1ALRak
Thanks for posting!!!
If it's a couple drops of oil per thousand miles, then what problem did you solve? The engine can handle a couple of drops per thousand miles.
Negative. The weep hole is primarily to evacuate the condensate that builds up. This is the problem the eco has. With the amount of oil and condensate combined, you will get the misfire and potentially hydrolock the engine. The weep hole is free insurance to protect against that.
What are you referring to as "negative" from my post? I was responding to jeje post and results after drilling.
A couple of drops at such a long interval does not sound problematic to me. However, this seems to be a problem for some.  Which tells me that either his results of a couple of drops actually did not solve a problem in evacuating liquid; his results are wrong; or this issue has been blown out of proportion.
I'm just trying to add up all the pieces here.
What comes out is not just a couple drops of oil. With the weep hole, the condensate that builds in the intercooler is evacuated to atmosphere. The small amount of oil buildup gets evacuated too.
The problematic piece of this is that a driver never knows when or how much condensate is in there. You only know when you floor the gas pedal and you get misfire / stutter. To prevent this, the 1/16" weep hole gets it out to atmosphere without issue. There are no ill effects or problems doing this. This and frequent (every 15k-20k miles) spark plug changes are what make this engine safer and more reliable.
AJP Turbo's comment on wheel torque error had me looking at the various files.
2015-2016 F-150 3.5 EB: 48,000
2012-2014 F-150 3.5 EB: 50,000
Maybe the files I saw already had the Ford fix implemented? The SHO is set to 35,000
