F-150 Overheating while towing
SHOdded said:
Are you thinking of the grille shutters, Z, that are used to speed up warmup?
Oh I know what you're talking about now.  No those grill shutters came on later years.  Mine doesn't have those.
SHOdded said:
Guy talks about towing with his 2013 EB F150
https://www.youtube.com/watch?v=9FXP-4FCexc
Mentions shifting to a lower gear, lower boost to keep the temps down.  Has a 5Star tow tune.
Yeah I saw that one.  My truck would be able to handle that short grade without a problem as well.  You have to remember, I was towing through the Rockies and the Sierra Nevada mountain ranges.  The grades are sustained for miles.  I couldn't see his IAT's in that video, but I suspect they were rising and if that grade were to keep up for another 5 miles, he would have a problem.  When searching the F150 forums, it sounds like people have had this problem stock and on other tunes as well.
Downshifting is how I lower the temps.  It seems like once the boost was below 8psi the intercooler could recover and temps would slowly decrease.
I made some ducting from the front bumper to the FMIC.  I used white zip ties to make it flashy.  :)
I'm towing 150 miles in the mountains today, so hopefully I'll see some difference in the IATs.  Although it's only 70* today.
I thought I'd update everyone on this.  The ducting with the stock IC helped, but temps would still climb when towing up steep inclines.  I found a used Wagner IC and bought that.
Wow.  I can't believe how the Wagner changed the IAT2!  Towing through the Colorado mountains and over to Moab, UT with 102* on the display, I feel like I thoroughly tested the new IC.  Temps are now 20-25* above ambient temperature at the IAT2.  With the stock IC temps were 50-60* above ambient when towing.  The cylinder head temps now climb more slowly.  Keeping the truck out of the red is much more manageable now.  It goes up hills at 70mph and as long as I drop a gear or two manually, the coolant temps stay out of the red.
I still think the cooling system in these trucks is inadequate.  I'd love to stay in 6th gear and keep the RPMs low when towing because I have the power to do so, but I have to downshift to keep the temps low.  I'm going to try a pusher fan on the front of the AC condenser first, but eventually will probably upgrade radiators.  BTW, I have the Max Tow radiator, which is the largest stock one.
The added power of the Wagner IC is nice too.  ;)
Well ... Keeping the gear out of 6th on long hills is a good thing as it saves the trans ...
Keeping it cool with Wagner :thumb:
