F150 3.5L EcoBoost HPFP FlexFuel Tune Release!
Livernois Motorsports is now releasing it's Flex Fuel upgrade system for the 2015-2016 F150 equipped with the 3.5 EcoBoost engine.
This system allows for use of all ethanol blend pump fuels up to full E85, all without the need of switching tunes, or manually checking ethanol content each time you fill up. Years of R+D have resulted in this upgrade system to allow your F150 to have true OEM-style flex fuel operation, allowing it to adjust the calibration to recognize and accommodate any amount of ethanol in the fuel system up to, and including 85%.
Featuring our Firestorm Upgraded High Pressure Fuel Pump and MyCalibrator tuner, this complete system allows for functionality people have been clamoring for for years, all while ensuring the safety, performance, and reliability that is the corner stone of the Livernois Motorsports line of products.
These charts attached below show the loss in fuel pressure with the stock pump vs. the corrected pressure issue with our Firestorm HPFP. There is also a LPH graph for the OEM vs Firestorm HPFP.
Stock Flow
Livernois Motorsports Firestorm HPFP
OEM vs. Firestorm HPFP - LPH
J-Will said:
This allows an individual to go from 93 to E85, and the back to 93 on the same tune?
Indeed it will, right now this is for the 15-16 F150 3.5 only, but we plan to expand it to all covered applications
derfdog15 said:
How much is this flex fuel system? What components need changed/modified, or is it all in the tune?
This is a complete system with pump, and calibration. you cannot go flex fuel without the pump, and you cannot use the pump without proper calibration, and definitely won't have flex fuel without our calibration.
FoMoCoSHO said:
Will this pump work on the OEM calibration?
No, it will not. It does require our MyCalibrator tuner to properly function.
Thats some pretty good R&D then!!!
