Pricing is releasted $949.00 list price - I am doing introductory pricing of $875.00 each and if I get 10 orders $25.00 off coupon will be put up.
You can order here:
http://shop.ecoboostpowerparts.com/ATP-Turbo-F150-Intercooler-ATPF150IC.htm
Front mounted intercooler upgrade. Direct replacement stock location unit. Garrett high density cores. Supports 800HP.
1. Stock Intercooler takes only 4.5 minutes to MAX OUT the air intake temp on the gauge. 157 Deg F.
2. After 4.5 minutes on the upgraded intercooler, maximum air intake temp observed is only 118 Deg F.
3. After 5.5 minutes of continuous pulls, the upgraded intercooler only reaches maximum temperature of 132 Deg F. It takes 12 consecutive dyno pulls in third gear to do this.
4. It takes the stock intercooler only 3 pulls (only 55 seconds) to reach the same 132 Deg. F
Conclusion: It does not take very long to heat soak the stock intercooler. In this case, it only takes 3 pulls in 3rd gear (about the same as 1/4 mile through 4 gears).
*Testing done Back to Back while Truck was strapped to the dyno.
Intercooler Torture Test - Upgraded Intercooler
Intercooler Torture Test - Stock Intercooler
You can order here:
You can order here:
You can order here:
