Finally got my '14 in the 12's
91hybrid
After a few aggravating months fighting my cars leaking turbo seals, which resulted in a best pass of 13.11@103 I finally decided to put on my meth kit that I had owned for 6 months. Results...12.51@109.7. There's a 12.4 left in her easy. This was the first time to the track with the meth install.  More to come next month.
Premeth:
Post meth:
Again, great job!
I'm looking at your 60' and wondering if that's better technique or your downpipes...
You're a little over 1/10th better.
Very nice!  Meth kits are usually good for 0.5 second drop in 1/4 times; your 60' times are great!  :thumb:
FoMoCoSHO said:
Again, great job!
All technique! Down pipes were already on. Only change was the meth and tuning for the meth.
The 13.11 pass was leaving at 2200 rpm with tires at 26 psi.
The  12.51 pass was leaving at the highest rpm my brakes could hold which was 2400-2500 with tires at 22psi.
Half a tenth is in the 60 foot is worth a tenth at the big end.
That's where I've been launching but I haven't messed with pressures yet. My brakes will hold more but it will dump boost if I try to rev higher.
I made my own. Bought stainless flanges and had the muffler shop bend me two pipes up and fitted it and welded it together. Cost me about $150 all said in done.
BMC10SEC50 said:
Where are you guys getting this third cat delete from??
I had it removed, the shop made me an Xpipe, I changed the mufflers for Dynomax mufflers, added two 4.5'' tips and all tubing in stainless steel 2.5''. They removed the original and replaced with their custom setup, all for 850$ Cdn tax in!
Hit the track last night. Same setup as last time, but I have been making some tune revisions with torrie....new best 12.206@113.03mph
I know a 12.1x is in her. I tried to get it on my last pass last night, had a 0.010 better 60', but then it spun insanely bad in 2nd so the pass was a bust. Pretty proud of her and torrie from where we started to where we are at right now.
Damn 91 great time!!!!  Definitely setting the bar for meth users.
Can't tell in your pic if your lowered, but if you get some lowered springs you might get into the 11's with better traction/weight transfer.
Thanks everyone. The power is in the tune, so all credit goes to torrie.
Stock pp suspension. Just playing with air pressure.
I'll try to upload the video.
FoMoCoSHO said:
How much boost you running?
Between 140 and 110 kpa (20 psi and 16 psi). My tiny snails are about maxed out though. Their running 85%-95% duty cycle.
