crash712us said:Dam nice time! Why are you running thru the water box? I ask because, the lowest ET guys out there avoid them. Cause it hurts their traction. I have never personally tried, so I cant say if helps or hurts my times.
Good observation. I've heard of people with treaded tires being given warnings not to do it again or leave. Even see rear wheel drive with slicks go around box then back into it, I'm guessing this is to not take water up to the line with the fronts.crash712us said:Dam nice time! Why are you running thru the water box? I ask because, the lowest ET guys out there avoid them. Cause it hurts their traction. I have never personally tried, so I cant say if helps or hurts my times.
Ahhh....we posted at same time91hybrid said:crash712us said:Dam nice time! Why are you running thru the water box? I ask because, the lowest ET guys out there avoid them. Cause it hurts their traction. I have never personally tried, so I cant say if helps or hurts my times.
I NEVER go through the water box! Your right, that's just asking for spinning. What you didn't get to see is me drive around it and then back up. I back up so I can hit the tires a little harder so I hopefully get them a bit more tacky and not roll through the lights.
crash712us said:Oops my bad, I guess that was just a assumption on my part. I was thinking how the hell can you run a 12.2 and go thru water box. I'd just sit and spin and the car would shut down and be luck to pull a mid 13 if I did that. If I didn't break anything. I work 60hrs this week I guess I am not running on all cylinders. LOL!
Lol, read my mind...SHOdded said:Asked Torrie if a little extra shot of ethanol would push you into the 11's?![]()
FoMoCoSHO said:Lol, read my mind...SHOdded said:Asked Torrie if a little extra shot of ethanol would push you into the 11's?![]()
How are you doing this without destroying the awd system?crash712us said:I've tried a E Brake burnout before. Works fine on the street, if done correctly. But at the track it sounded like the engine banged against the firewall. So I don't do it anymore, but stiffer engine mounts would be helpful.
