Ford Explorer
RECALL Subject: Rear Suspension Toe Link may be Improperly Welded
Report Receipt Date: APR 26, 2016
NHTSA Campaign Number: 16V245000
Component(s): SUSPENSION
All Products Associated with this Recall
FORD EXPLORER 2014-2015
Details
Manufacturer: Ford Motor Company
SUMMARY:
Ford Motor Company (Ford) is recalling certain model year 2014-2015 Ford Explorer vehicles manufactured January 17, 2014 to May 31, 2014. The affected vehicles may have improperly welded rear suspension toe links that may fracture.
CONSEQUENCE:
A fracture of the rear suspension toe link may result in a loss of steering control, increasing the risk of a crash.
REMEDY:
Ford will notify owners, and dealers will replace the rear suspension toe links, free of charge. Interim notices were mailed to owners on June 9, 2016. Owners will receive a second notice when remedy parts become available. Owners may contact Ford customer service at 1-866-436-7332. Ford's number for this recall is 16S18.
NOTES:
Owners may also contact the National Highway Traffic Safety Administration Vehicle Safety Hotline at 1-888-327-4236 (TTY 1-800-424-9153), or go to www.safercar.gov.
Use our VIN Look-Up tool to see if your vehicle is affected
by this recall (major light vehicles only):
2019
https://www.ecoboostperformanceforum.com/index.php/topic,6720.msg153757.html#msg153757
Cooling Fan Noise – 2016 Ford Explorer
oemdtc July 26, 2016 Diagnostic Tips
2016 Explorer Built On Or Before 5/8/2016 – Cooling Fan Noise
Some 2016 Explorer vehicles built on or before 5/8/2016 may exhibit a noise from the electric cooling fans, most noticeable right after the engine is turned off as they spin down to a stop.
If the noise can be pinpointed to the cooling fan motor, replace the cooling fan assembly with applicable updated service parts.
DA8Z-8C607-B replaced DA8Z-8C607-A, DG1Z-8C607-E replaced DG1Z-8C607-D, DG1Z-8C607-F replaced DG1Z-8C607-A, DB5Z-8C607-D replaced DB5Z-8C607-C.
Refer to Workshop Manual (WSM,) Section 303-03. Use available Service labor times in section 08.
Lower Roll Restrictor Rubber Strap Loose – 2016-2017 Ford Explorer
oemdtc July 2, 2016 Info
2016-2017 3.5L and 3.7L Explorer Lower Roll Restrictor Rubber Strap Loose
Some 2016-2017 Explorers equipped with the 3.5L and 3.7L TiVCT engine may have a rubber loop integral to the heat shield on the lower roll restrictor appearing to be loose or broken.
The purpose of the loop is to keep the heat shield in place prior to vehicle assembly.
Once the roll restrictor is installed on the vehicle, the rubber loop is not necessary to retain the heat shield to the roll restrictor.
This loop may be removed.
It is not necessary to replace the roll restrictor for this issue.
Sound familiar? LOL!
3.5L Gasoline Turbocharged Direct Injection (GTDI) Engine P0327/P0332 – 2016 Ford Explorer
oemdtc June 2, 2016 Diagnostic Tips
2016 Explorer with 3.5L Gasoline Turbocharged Direct Injection (GTDI) Engine, P0327/P0332
Some 2016 Explorer vehicles equipped with a 3.5L Gasoline Turbocharged Direct Injection (GTDI) engine may exhibit a Malfunction Indicator Lamp (MIL) with Diagnostic Trouble Codes (DTC) P0327/P0332.
This may be caused by a wire chafe condition near the Knock Sensor connector C109.
If a chafing condition is found, service the part as necessary and secure wiring to prevent reoccurrence.
If no chafing is found, verify C109 is properly seated, all terminals are free of damage or corrosion and that the sensors are at the specified torque per Work Shop Manual(WSM) Section 303-14B.
If no problems are found, continue with normal diagnostics per WSM Section 303-14B.
EXHAUST ODOR IN VEHICLE
Publication Date: December 15, 2016
FORD: 2011-2015 Explorer
This article supersedes TSB 16-0165 to add a causal basic part number and condition code.
ISSUE:
Some 2011-2015 Explorer vehicles may exhibit an exhaust odor in the vehicle with the auxiliary climate control system on. Customers may indicate the odor smells like sulfur, or that exhaust odors are entering the vehicle cabin. This condition may be worsened when the climate control system is in recirculate mode and the vehicle is heavily accelerated for an extended period. Whether and to what extent any customer or occupant of a 2011-2015 Explorer vehicle experiences the exhaust odor will be affected by driving habits, weather and individual sensitivities.
ACTION:
Follow each and every step of the Service Procedure in procedure 1 to improve the condition.
SERVICE PROCEDURES
Note: The Service Procedure consists of 2 separate repair routines. Most vehicles will not require the second procedure.
Procedure 2 does not apply to vehicles equipped with the 2.0L Gasoline Turbocharged Direct Injection (GTDI) and 3.5L GTDI engines.
Note: The body sealing steps in this procedure are critical elements in helping to manage subjective odor concerns.
    Is the customer returning with the exhaust odor complaint after Procedure 1 was completed?
        No – proceed to Procedure 1.
        Yes – Is the vehicle equipped with the 3.5L Twin Independent Variable Cam Timing (Ti-VCT) engine?
            Yes – proceed to Procedure 2.
            No – the procedure does not apply. Continue with normal diagnostics.
PROCEDURE 1
1.    Reprogram the heating ventilation air conditioning (HVAC) module to the latest calibration using IDS release 101.03 or higher. Make sure you are connected to the internet when entering module programming to obtain the latest updates. Calibration files may also be obtained at www.motorcraftservice.com.
        When reprogramming the HVAC, IDS will have additional questions which will require a yes response to reprogram the module.
2.    Remove the rear bumper cover. Refer to Workshop Manual (WSM), Section 501-19.
3.    Remove the left and right tail lamps. Refer to WSM, Section 417-01.
4.    Remove the wheel lip mouldings. Refer to WSM, Section 501-08.
5.    Open the liftgate and inspect for presence of drain valves in the two (2) drain holes on the left and right side of the liftgate. Are the drain valves present? (Figure 1)
    drain valve
    Figure 1
        Yes – proceed to Step 7.
        No – proceed to Step 6.
6.    Install a new drain valve in each of the two (2) drain holes on the left and right side of the liftgate. (Figure 1)
7.    Inspect the liftgate seal for damage and proper fit/contact pattern. Adjusting the rear liftgate striker so that the rear hatch seals tighter to the liftgate seal is important. This can be done by loosening the striker and moving it to increase the liftgate sealing pressure.
8.    Inspect the left and right side air extractors for proper fit to the body and operation/sealing of the rubber flaps.
        Replace the air extractor if it is warped or damaged or flaps do not lay flush to their sealing surface. (Figure 2)
air extractor Figure 2
9.    Inspect and verify proper installation of the wire harness grommets and body plugs in the liftgate opening, quarter panels under the tail lamps, license plate and bumper cover and the rear underbody area.
10.    Using masking tape, seal the left and right air extractor vents and the rear auxiliary climate control drain tube.
        Make sure to tape off only the vents and not the area around the air extractor where it seals to the body of the vehicle.
11.    Start the vehicle and set the front climate control to fresh air mode and front blower speed to HI. Turn the rear climate control off.
12.    Make sure all windows are up and all doors are closed in order to pressurize the cabin.
13.    Use soapy water (dish soap or bubble bath works best-not bar soap) in a spray bottle to help locate air leaks.
        Spray the underbody seams, rubber grommets, rear wheel well seams, tail lamp seams, liftgate seals, quarter glass seals, license plate area, liftgate hinge area, auxiliary a/c seals and the area where air extractors mount in the body.
14.    Air leaks will be identified by the presence of air bubbles. Mark the location of any leaks.
15.    Turn off the a/c and shut the vehicle off.
16.    Clean and dry all marked areas and seal using Motorcraft Seam Sealer.
17.    Raise the vehicle on a hoist. Refer to WSM, Section 100-02.
18.    Lower and support the rear section of the exhaust system.
19.    Clean areas on the underside of the vehicle where seam sealer will be applied. (Figures 3-5)
areas on the underside of the vehicle where seam sealer will be applied Figure 3
areas on the underside of the vehicle where seam sealer will be applied Figure 4
areas on the underside of the vehicle where seam sealer will be applied Figure 5
20.    Cover the exhaust system and verify the auxiliary climate control drain tape is still in place.
21.    Apply a generous amount of Motorcraft Seam Sealer to the following areas:
        The rear horizontal sheet metal lap joints on left and right sides of the vehicle.
        The rear sheet metal overlap flange across the rear of the vehicle. (Figures 3-5)
22.    Spray a generous amount of 3M Rubberized Undercoating around the auxiliary air conditioning lines and seam sealer areas. (Figure 6)
auxiliary air conditioning lines Figure 6
23.    Remove the tape from the air extractors and auxiliary climate control drain.
24.    Install the rear exhaust system.
25.    Install the wheel lip mouldings. Refer to WSM, Section 501-08.
26.    Install the rear bumper cover. Refer to WSM, Section 501-19.
        Apply masking tape around the outer edge of the rear fender mouldings to protect the vehicle from damage.
27.    Install the tail lamps. Refer to WSM, Section 417-01.
28.    Is the vehicle equipped with the 3.5L Ti-VCT engine?
        Yes – return the vehicle to the customer for evaluation, close out the repair order and submit the claim for payment.
            Procedure 2 can be performed if the customer returns with the same complaint.
        No – return the vehicle to the customer, close out the repair order and submit claim for payment.
            Procedure 2 does not apply to the vehicle.
PROCEDURE 2
1.    Guided Routine  Click here to access Guided Routine. Does the vehicle meet necessary conditions?
        Yes – proceed to Step 2.
        No – return vehicle to the customer. No additional repairs are available.
2.    Inform the customer of the redesigned exhaust tips and that appearance will remain the same but the exhaust will exit the tip from bottom. Upon acceptance, replace the muffler assembly with the updated part containing the down turned exhaust tips. (Figures 7-8)
exhaust tips Figure 7
exhaust tips Figure 8
3.    Return the vehicle to customer.
Obtain Locally
Part Number Part Description
08883 3M Rubberized Undercoating
PART NUMBER PART NAME
BB5Z-61280B62-B Dual Rate Air Extractor
BB5Z-7829164-AA Wheel Lip Moulding Right Side
BB5Z-7829165-AA Wheel Lip Moulding Left Side
4M8Z-54280B62-A Valve Assembly Auto Drain
TA-2-B Motorcraft Seam Sealer
EB5Z-5230- A Muffler Assembly
OPERATION DESCRIPTION TIME
160166A 2011-2015 Explorer 3.5L Ti-VCT: Perform Web Assessment, Obtain Repair Verification Code (RVC) And Replace The Muffler Assembly Following Procedure 2 (Do Not Use With Any Labor Operations Outside Of This Article) 0.7 Hr.
MT160166 2011-2015 Explorer: Reseal The Body Following Procedure 1 Includes Time To Reprogram The HVAC Module (Do Not Use With Any Labor Operations Outside Of This Article) Actual Time
WARRANTY STATUS
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage.
Warranty/ESP coverage limits/policies/prior approvals are not altered by a TSB. Warranty/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool.
DEALER CODING
BASIC PART NO. CONDITION CODE
61280B62 42
2.3L GASOLINE TURBOCHARGED DIRECT INJECTION (GTDI) – ILLUMINATED MALFUNCTION INDICATOR LAMP (MIL) – LACK OF POWER – DTC P0299
Publication Date: September 14, 2016
2016 Explorer
ISSUE:
Some 2016 Explorer vehicles equipped with a 2.3L GTDI engine may exhibit an illuminated MIL with a lack of power and diagnostic trouble code (DTC) P0299. This may be due to the turbocharger wastegate actuator rod coming disconnected from the wastegate.
ACTION:
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
1. Using the Integrated Diagnostic System (IDS) service tool or an equivalent scan tool, check for DTCs. Is DTC P0299 present in the powertrain control module (PCM) memory?
a. Yes – proceed to Step 2.
b. No – this article does not apply. Refer to Powertrain Control/Emissions Diagnosis (PC/ED) manual for normal diagnostics.
2. Inspect the turbocharger wastegate actuator rod for proper engagement to the wastegate lever. Is the turbocharger wastegate actuator rod properly attached and the retaining clip in place?
a. Yes – this article does not apply. Refer to the PC/ED manual for normal diagnostics.
b. No – proceed to Step 3.
3. Remove the engine undershield. Refer to Workshop Manual (WSM), Section 501-02.
4. Remove and discard the upper turbocharger mounting nuts. (Figure 1)
Figure 1
5. Remove the lower turbocharger heat shield retaining bolt. (Figure 1)
6. Position the turbocharger heat shield aside.
a. It is not necessary to remove the turbocharger coolant lines to position the heat shield aside.
7. Reconnect the turbocharger wastegate actuator rod and install a new retaining clip. (Figure 2)
Figure 2
a. For front wheel drive (FWD) vehicles access the turbocharger wastegate actuator rod from underneath the vehicle.
b. For all wheel drive (AWD) vehicles remove the right front wheel and tire. Refer WSM, Section 204-04. Access the turbocharger wastegate actuator rod through the wheel opening.
8. Install the turbocharger heat shield.
a. Tighten the new upper turbocharger mounting nuts. Torque to 50 Nm (37 lb-ft).
b. Tighten the lower turbocharger heat shield retaining bolt. Torque to 10 Nm (89 lb-in).
9. Install the engine undershield. Refer to WSM, Section 501-02.
W790436-S900 Retaining Clip
W713095-S403 Nut – Turbocharger-to-Manifold
W716042-S900 Bolt – Turbocharger-Lower-Heat-Shield
W704474-S437    Stud – Turbocharger-to-Manifold
160122A 2016 Explorer FWD 2.3L GTDI: Inspect And Reconnect The Actuator Rod With New Retaining Clip Following The Service Procedure (Do Not Use With Any Other Labor Operations) 0.5 Hr.
160122B 2016 Explorer AWD 2.3L GTDI: Inspect And Reconnect The Actuator Rod With New Retaining Clip Following The Service Procedure (Do Not Use With Any Other Labor Operations) 0.6 Hr.
WARRANTY STATUS
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage.
DEALER CODING
6K682 39
HANDS-FREE LIFTGATE – WITHOUT TRAILER TOWING PACKAGE – LIFTGATE OPENS WHEN WALKING NEXT TO THE REAR BUMPER
Publication Date: August 2, 2016
2016 Explorer
ISSUE:
Some 2016 Explorer vehicles equipped with the hands-free power liftgate and without trailer tow package may exhibit a liftgate that opens while walking next to the rear bumper. This may be due to the software sensitivity in the hands-free liftgate actuation module.
ACTION:
SERVICE PROCEDURE
Replace the hands-free liftgate actuation module. Refer to Workshop Manual (WSM), Section 501-03.
GB5Z-14B291-F Hands-Free Liftgate Actuation Module
160102A 2016 Explorer: Replace The Hands-Free Liftgate Actuation Module (Do Not Use With Any Other Labor Operations) 0.3 Hr.
WARRANTY STATUS
DEALER CODING
14B291 04
2016-2017 Explorer Police Utility – Illuminated Malfunction Indicator Lamp (MIL) – Diagnostic Trouble Code (DTC) P0073
Some 2016-2017 Explorer Police Utility vehicles may have an illuminated MIL with Ambient Air Temperature Sensor DTC P0073.
During the installation of certain police accessories by non-Ford vehicle upfitters, wiring connector C134 may have been left disconnected following the removal and installation of the front bumper cover.
If this issue is noted, first check C134 before beginning other diagnostic steps.
Reconnecting C134 due to improper reassembly by an outside supplier is not a warrantable repair.
2015-2016 Edge, Explorer, Mustang, and F-150 Various Engines – Oil Leak At Engine Oil Pressure (EOP) Sensor Threads
Some 2015-2016 Edge with 2.0L Gasoline Turbocharged Direct Injection (GTDI), 2015-2016 Mustang and F-150 with 5.0L engine and 2016 Explorer equipped with 2.3L GTDI engine may exhibit oil leak at engine oil pressure (EOP) sensor threads.
It is not required to replace the sensor if it is leaking from the threads.
Remove and reseal the EOP sensor, refer to Workshop Manual (WSM), Sections 303-14.
Check the oil level and top off as necessary.
Refer to WSM, Section 303-01.
2011-2015 Explorer/MKT – Right Front Axle Shaft Heat Shield Deletion
2011-2015 Explorer and MKT vehicles requiring replacement of right front axle shaft no longer require installation of the center support bearing heat shield (7F469).
The heat shield can be discarded.
2017 Expedition – Keyed Ignition – Doors Will Not Lock Using The Keyless Entry Keypad – Built On 14-OCT-2016 And Through 22-OCT-2016
Some 2017 Expedition vehicles built on 14-OCT-2016 and through 22-OCT-2016 with a keyed ignition (non-push button start) may have inoperative door locks when using the keyless entry keypad.
Reprogram the Body Control Module (BCM) to the latest calibration using IDS release 104.02 or higher.
Manufacturer Communication Number: SSM 45926
Summary
2013-2017 FUSION/ESCAPE/MKZ (EXCLUDING 3.7L), 2015-2016 EDGE/EXPLORER (EXCLUDING 3.5L/3.7L), 2015-2016 MKC, AND 2016 MKX VEHICLES (EXCLUDING 3.7L) EQUIPPED WITH ALL WHEEL DRIVE (AWD) MAY EXHIBIT A LEAKING PASSENGER SIDE POWER TRANSFER UNIT (PTU) HALFSHAFT/LINKSHAFT SEAL. THIS MAY BE DUE TO A WORN PTU BUSHING. THE PTU BUSHING CAN NOW BE REPAIRED WITHOUT PTU REPLACEMENT. THE ONLINE WSM IS BEING UPDATED FOR ALL LISTED VEHICLES.REFER TO THE INTERMEDIATE SHAFT BUSHING REMOVAL AND INSTALLATION IN WORKSHOP MANUAL (WSM), SECTION 308-07. THE PROCEDURE IS THE SAME FOR ALL VEHICLES. IF THE PROCEDURE IS NOT PUBLISHED FOR THE VEHICLE BEING SERVICED CHECK THE WSM OF ANOTHER LISTED VEHICLE. BUSHING PART NUMBER IS F2GZ-63600A58A. THE PARTS CATALOG IS BEING UPDATED TO INCLUDE THIS BUSHING.
Vehicles
MAKE    MODEL    YEAR
FORD    EDGE    2015-2016
FORD    ESCAPE    2013-2017
FORD    EXPLORER    2015-2016
FORD    FUSION    2013-2017
LINCOLN    MKC    2015-2016
LINCOLN    MKX    2016
LINCOLN    MKZ    2013-2017
2016 Explorer – Diagnostic Trouble Code (DTC) U3000 After Heating Ventilation Air Conditioning (HVAC) Calibration Update And/Or Module Replacement
Some 2016 Explorer vehicles may exhibit a DTC U3000:49 after a HVAC calibration update and/or module replacement.
Diagnose all other symptoms and DTCs first.
If no additional DTCs or symptoms are present, disregard this DTC.
Do not attempt repairs at this time.
Engineering is investigating.
2017 Explorer/Taurus/Police – 3.5L or 3.7L TiVCT Engine – Illuminated MIL – DTC P0740 or P0743 – Built On 14-Jun-2017 And Through 21-Jun-2017
Some 2017 Explorer/Taurus/Police vehicles equipped with a 3.5L or 3.7L twin independent variable camshaft timing (TiVCT) engine, built on 14-Jun-2017 and through 21-Jun-2017, may exhibit an illuminated malfunction indicator lamp (MIL) with diagnostic trouble codes (DTCs) P0740 or P0743 stored in powertrain control module (PCM) memory.
Prior to replacing any components, check pin 14 in connecter c168 for correct fitment, tension, push out, or any signs of damage.
If terminal replacement is necessary, pigtail kit 8U2Z-14S411-ACB can be ordered to obtain the terminal with wire lead.
If no concerns are found with C168, follow normal diagnostic routines for the fault codes.
FORD RECALLS 202,000 EXPLORER SUVS AND F-150 TRUCKS
DECEMBER 1, 2017Ford is recalling more than 202,000 model year 2016 Ford Explorer SUVs The recalled 2016 Ford F-150 trucks were built in Michigan and Kansas City between January 22, 2016, and April 19, 2016, and the recalled 2016 Ford Explorers were built in Chicago during the same time period.
Ford dealers will handle the recall repairs in two ways. Dealers will measure the torque of the power seat pivot link bolt and if the bolt passes inspection, dealers will remove and clean the bolt, apply new threadlock and reinstall the bolt using the correct torque.
However, if the bolt fails inspection, Ford technicians will apply new threadlock and the bolt will be reinstalled as an interim repair until the final repair is available. The final repair will have dealers replacing the lift links with new bushings and fasteners.
Owners of 2016 Ford Explorer SUVs and Ford F-150 trucks may contact Ford at 866-436-7332 and use reference number 17S40
Ford F-150 trucks because the front power seat cushions can loosen and cause problems in a crash.
About 177,000 of the recalled vehicles are in the U.S., another 22,620 are in Canada and nearly 2,400 are recalled in Mexico.
Ford says upper left-hand pivot bolts can loosen and fall out of the front power seat adjusters, leaving the front seat cushions to move around in a crash. However, the automaker says it's unaware of any crashes or injuries related to the loose pivot bolts.
The recalled 2016 Ford F-150 trucks were built in Michigan and Kansas City between January 22, 2016, and April 19, 2016, and the recalled 2016 Ford Explorers were built in Chicago during the same time perioiod.
  http://m.carcomplaints.com/news/2017/ford-recalls-explorer-suvs-f-150-trucks.shtml
November 11, 2017
SSM 46905 – 2015-2018 – Explorer – Hankook Brand Tire – Chipping, Cutting And/Or Unusual/Accelerated Tread Wear
Some 2015-2018 Explorer vehicles equipped with Hankook brand tires may exhibit chipping, cutting and/or unusual or even accelerated tread wear.
If the tire side wall is marked as: 255/50R20 105H Ventus S1 Noble 2 contact Hankook Technical Service for possible pro-rated tire replacement.
This may not be the result of improper alignment.
For Hankook contact information refer to the Tire Warranty information located on FMCDealer.com.
APPLICABLE VEHICLES
2015 – 2018 TRUCK: UB EXPLORER
November 10, 2017
SSM 46888 – 2017 Explorer – 110V Power Inverter – High Pitched Buzzing/Ringing Noise With Engine Running From Passenger Side Front Interior
Some 2017 Explorer vehicles equipped with a 110V power inverter may exhibit a high pitched buzzing or ringing noise from the passenger side front interior area while the engine is running.
To isolate the noise to the power inverter, remove fuse 56 from the battery junction box with the engine running.
Make sure there is nothing plugged into the 110V outlet during the test.
If the noise is no longer present with the fuse removed, the noise is isolated to the inverter and no other components should be replaced.
Replacement of the inverter may not resolve the noise.
Engineering is aware of the concern and is investigating.
The noise does not affect the operation of the power inverter.
Please submit a Global Concern Report and continue to monitor OASIS for updates.
APPLICABLE VEHICLES
2017 TRUCK: UB EXPLORER
October 22, 2017
2017 Explorer/Taurus/Police Interceptor – Fixed Brake Pedal – Brake Drag – Built On 19-May-2017 And Through 30-May-2017
Some 2017 Explorer, Taurus, Police Interceptor vehicles built on 19-May-2017 and through 30-May-2017 equipped with a fixed brake pedal assembly may exhibit a brake drag concern or residual pressure in the brake system with the brake pedal fully released.
This may be due to an interference condition between the brake pedal arm stop lamp switch bracket and the booster push rod clevis pin bracket.
Inspect for a touch condition between the brake pedal arm stop lamp switch bracket and the brake booster push rod clevis pin bracket.
If a touch condition exists, replace the brake pedal assembly.
