SSM 47488 – 2018 Explorer/Police Interceptor Utility – No Crank/Discharged Battery/Battery Drain – Base Level IPC – Built On 08-May-2018 And Through 05-Aug-2018
Some 2018 Explorer/Police Interceptor Utility vehicles equipped with Police, Base 100A, or XLT 200A package trim levels (Type 1 analog cluster in the Owner’s Manual) built on 08-May-2018 and through 05-Aug-2018 may exhibit a parasitic battery drain of approximately 250 milliamps with the instrument panel cluster (IPC) possibly staying awake with the key off.
This may result in a no crank/no start/discharged battery condition.
To resolve the concern, reprogram the IPC using the latest software level of the appropriate Ford diagnostic scan tool.
For claiming, use causal part 10849 and applicable labor operations in Section 10 of the Service Labor Time Standards (SLTS) Manual.
APPLICABLE VEHICLES
2018 TRUCK: UB U502N EXPLORER
Service Information & Reprogramming
Module Reprogramming
Diagnostic Software Interface Device Complete Vehicle Diagnostics Module Programming
1996-2017 2018-Present 1996-2017 2018-Present
Model Year Model Year Model Year Model Year
IDS/FDRS VCM, VCM II, VCMM X X X X
FJDS/FDRS Compatible J2534
Devices (Including
VCM II and VCMM) X X X
Detailed system requirements, installation, and support information for each product is located under the diagnostics tool support tab for each product.
Integrated Diagnostic Software (IDS) / Ford Diagnosis & Repair System (FDRS)
For use with VCM I, VCM II, VMM and VCMM hardware devices only. The complete factory Ford Motor Company vehicle diagnostic tool that provides complete dealership level vehicle diagnostic coverage for all 1996 to present Ford, Lincoln and Mercury vehicles. The IDS software includes time based access to the IDS software, software updates and calibration files.
Ford J2534 Diagnostic Software (FJDS) / Ford Diagnosis & Repair System (FDRS)
For use with compatible J2534 hardware devices. FJDS software provides Ford Module Programming functionality that covers 1996 to present Ford, Lincoln and Mercury module reprogramming functions, plus complete dealership level vehicle diagnostic software for all 2018 to present Ford and Lincoln vehicles. The FJDS software license includes time based access to the FJDS software, software updates and calibration files.
Latest Calibration Information
https://www.motorcraftservice.com/Reprogramming/Calibration
Module Build Data (As-Built)
https://www.motorcraftservice.com/AsBuilt
Use VIN to obtain As-Built data
