Ford To Fix Smoky Engines On Explorer, Taurus, Flex, MKS, MKT
Good job, Ford!  I wish owners could lookup themselves if their car is affected.  How do they determine?  Surely must be EVERY SHO, right?
I'm emailing my dealer right now.
Talked to my dealer, they do not have the parts in yet, But think they should have them in a few weeks.  He stated that it should also fix intake deposits and eliminate the need for a catch can.,
This repair is labor intensive and can take up to three hours, so plan on leaving the vehicle for the day. For more info or answers to questions contact Ford at 800-392-3673 or Lincoln at 800-521-4140. Reference Ford TSB Number: 14-0114 entitled: Engine - Intermittent Rough Idle, Rattle Noise While Driving.
My dealer responded:
THAT IS INTERESTING, I LOOKED UP THAT TSB  14-0114 5.4L 3V – INTERMITTENT RATTLE NOISE WHILE DRIVING / ROUGH IDLE WHEN ENGINE IS AT OPERATING TEMPERATURE
BUT IT DOESN’T REFERENCE THE ECOBOOST ENGINE AT ALL.  THIS ONLY PERTAINS TO THE 5.4 3 VALVE ENGINES.  I THINK MAYBE THEY GOT AHEAD OF FORD ON RELEASING THAT STORY IF THEY HAVE A TSB COMING OUT FOR THE ECOBOOST ENGINE.
THE NEWEST VEHICLE THAT THE TSB REFERS TO IS 2013 EXPEDITION OR NAVIGATOR.
This a TSB (or eventually will be), not a recall. With my experience, there's a reluctance to perform TSBs, without evidence of an associated symptom. For example, smoke from the tail pipe (which isn't exhibited on my SHO)...
I doubt dealers will oblige to performing a TSB, just by request.
Anyone have the number of this TSB?... the one in all the articles references problems with the 5.4 engine...
TSB 14-0114 deals with rattle noise and rough idle on the 5.4
Thanks!  That's what I needed.... The articled linked in the first post says it is 14-0114, but I knew that couldn't be right.  Thanks again...
Anyone have a reliable link to this TSB ... Or a copy so we can read the info directly...TIA
I found the information below online.  Unless the car is exhibiting these symptoms, I doubt that the TSB would be applied under warranty.
FORD:
2010-2014 Flex, Taurus
2013-2014 Explorer
LINCOLN:
2010-2014 MKS, MKT
ISSUE
Some 2010-2014 Flex, MKS, MKT, Taurus and 2013-2014 Explorer vehicles equipped with a 3.5L Gasoline
Turbocharged Direct Injection (GTDI) engine with an aluminum valve cover may exhibit excessive oil consumption and/or
excessive engine oil smoking condition from the tail pipe at idle during normal engine operating temperatures.
ACTION
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
1. Remove the positive crankcase ventilation (PCV) Valve. Refer to Workshop Manual (WSM), Section 303-08.
2. Inspect for oil in the crankcase vent oil separator through the PCV valve opening. Is there presence of liquid oil, more
than slight vapor?
a. No - this article does not apply refer to WSM, Section 303-00 for Excessive Engine Oil Consumption.
b. Yes - proceed to Step 3.
3. Replace the right hand valve cover, refer to WSM, Section 303-01D.
4. Replace the crankcase vent oil separator, refer to WSM, Section 303-08.
5. Drive the vehicle at normal operating temperature for 20 minutes at constant highway speed to remove oil residue
from catalytic converter.
__________________
I had talk with some other car guys about intake cleaning. We think that having and using METH will help keep the intake and vale clean to. What do you guys think?
I believe that I already stated that we should petition FMC to call a TSB for the installation of meth kits on all Ecoboost cars and trucks. And all future cars and trucks should come equipped with a meth kit from the factory! ;) clean engine, check. More powa, check.
