67inhg max..802SHO said:How much PSI are you tuned for?
So 18.2 psi of booat at sea level. Boost isn't everything. These turbos flow.mattr66 said:67inhg max..802SHO said:How much PSI are you tuned for?
Yep mire left in it but want to to keep stock rods in the block.802SHO said:I agree that boost is not everything. 18.2 boost at that power level? That's very impressive to me. Well within efficiency level?
mattr66 said:Yep mire left in it but want to to keep stock rods in the block.802SHO said:I agree that boost is not everything. 18.2 boost at that power level? That's very impressive to me. Well within efficiency level?
Yes I am trying to stay around 500 torque to the tires. I could easily generate enough power to kink them.... LOL802SHO said:mattr66 said:Yep mire left in it but want to to keep stock rods in the block.802SHO said:I agree that boost is not everything. 18.2 boost at that power level? That's very impressive to me. Well within efficiency level?
You have mentioned before I believe that your upgraded turbos are perfect for our engines without doing a built motor. Based on what you have just explained I would be inclined to believe your turbos can also support a built motor?
mattr66 said:Yes I am trying to stay around 500 torque to the tires. I could easily generate enough power to kink them.... LOL802SHO said:mattr66 said:Yep mire left in it but want to to keep stock rods in the block.802SHO said:I agree that boost is not everything. 18.2 boost at that power level? That's very impressive to me. Well within efficiency level?
I edited the part numbers and added the Rock Auto screenshot. The copper washers are for the oil line going into the top of the turbo. The 2 aluminum washers are for the coolant in and outlet lines. Seems like they would have you replace everything unless the oil inlet line is already attached.StealBlueSHO said:mrhighcaliber said:Just a note to anyone whom is doing future turbo r&r should get the MAHLE gasket kits.StealBlueSHO said:Here is the recommended replacement hardware parts list for the Gearhead turbos. You don’t HAVE to replace these... but highly recommended!! This was ordered through Tasca.
P/N# GS33733 and GS33734.
left and right.
Comes with:
1x Turbo to manifold Gasket
1x Turbo to Down pipe Gasket
2x Aluminum Coolant line gaskets
1x Copper oil line inlet gasket
2x Rubber oil drain tube to block O-rings
1x Turbo to oil drain tube gasket
-Per Kit
Price range Rock Auto to eBay is 27.99 to 32.99 per kit.
This is my second time using these kits. Oh and SBS, you require 2 turbo pipe O-rings per side. 4 total. Each drain tube has 2 where is slides into the block. Unless those are packs of 2 on your list.![]()
Sent from my PH-1 using Tapatalk
I’m basing this off what Gearhead sent me.
If there is other stuff I need to order let me know....
I didn’t order any copper stuff since it wasn’t on the list.
-Mike
2k plus core18SHO said:mattr66 said:Yes I am trying to stay around 500 torque to the tires. I could easily generate enough power to kink them.... LOL802SHO said:mattr66 said:Yep mire left in it but want to to keep stock rods in the block.802SHO said:I agree that boost is not everything. 18.2 boost at that power level? That's very impressive to me. Well within efficiency level?
How much are we looking at for this kit Matt?
