Gearing acting up help please
AdrianSHO
Hey guys so last night I was driving and my car basically just stopped driving and started acting like it was in neutral no matter what gear I was in. When I came to a stop in drive it won't take off until my car revs up to 5k it almost seems like my car is half in neutral and half in drive it also does it in reverse. Any thoughts on what it might be? Anything helps thanks guys
So far I have no codes and yeah I fixed the solenoid and it fixed my issue before but I'll check that out and see what happens
AdrianSHO said:
What's the location of that sensor
Should be inside the main control cover, visible when you remove the air box and ducting assembly.  The following are all accessible through this cover:  tss sensor, oss sensor, trs sensor, valve body, and solenoid body assembly.
ZSHO said:
Did you Disconnect the battery @ one point ?
Haha it's a good point I definitely thought about it so I might as well give that a try tonight when I'm home if not I'll refer to those sensors!
glock-coma said:
Any noises? Wasn’t there a tsb for the half shaft separating awhile back?
Yeah it doesn't sound the best when I turn it on and shift through the gears you can hear it pretty good by my front driver side tire
This what I was referring to
https://www.google.com/amp/www.techtimes.com/amp/articles/13133/20140816/ford-recalls-83-250-edge-taurus-flex-and-lincoln-vehicles-over-power-loss-problem.htm
