So one of the things I hate about Gen 4.1 is having to wait for OAR to scale.
Wait no more!
I'm AJP/SCT tuned so I don't know if it will carry across different hardware/tuners.
All you need if the right road/traffic and you can raise it at will (less than 1 mile today)
Make sure you are in highest gear possible and lock that gear. Roll into the throttle until your knock sensor maxes at -4 and let off...you will see it raise by about -.2 every time. Coast/decel rinse and repeat until your OAR is fully scaled. I think there might be a time component (spent at -4) that gives your some extra per pull. For you Unleashed guys Torrie has been known to change global knock to -5 so I don't know if -4 or -5 will be your trigger.
*Caution* Do not stomp the throttle or your could trigger an LSPI situation. Meth guys, remember your meth won't be spraying so that warning still applies.
This may be more of a challenge if you are dealing with weaksauce 93 octane or your knock sensor is set to ramp slowly.
Enjoy!
Wait no more!
Enjoy!
