H&R lowered, alignment question
I'm not 100% but I believe Mike (EPP) mentioned in one of his suspension posts early on that you have to use a shallow/thinner nut.
sent from my speak n' spell using tin cans and string
slurppie said:
I'm not 100% but I believe Mike mentioned in one of his suspension posts early on that you have to use a shallow/thinner nut.
That makes sense because the nut is too thick to grab on and tighten it. Do you know which thread it was.
I believe it's in here, http://www.ecoboostperformanceforum.com/index.php?topic=611.msg4249.msg#4249
The nut used must be shallower.
I authored that "How-To" quite a few years ago.
Mind you it's been 5yrs, but from what I recall, the nut supplied by Specialty Products with their adjustable rear camber bolt, was hitting on something.
It forced me to research/purchase a shallower in height nut.
No problems whatsoever since I originally performed this mod.
