hard starts
Twinpops13
I have a 2013 ford explorer sport, the issue I have is after it sits overnight , the first time I push ignition button it just turns and sounds like it needs fuel. I have changed the vapor canister purge solenoid. and the problem came back again this afternoon as I just went to check to see if it would start on first try.
does anyone have a clue I have no codes at all.thanks
Could be a dying battery or fuel pump control module.  Check the CCAs on the battery with a digital tester like the Solar BA7.
