Having an issue. Video attached
brandont
I am having an issue. I had some codes tossed p008b and p0234 and this is what it was doing. Any idea of why it's doing this????
Ecoboost: http://youtu.be/Pfi0gweKaj4
Glad to see you joined after the suggestion to on facebook. After the gurus here guide you through troubleshooting this, a good new member into with pics will be on tap I hope.
Good luck!
I guess as a DIY you can check to make sure the wiring & clamps/screws on the MAP sensor and the Turbocharger Boost Pressure (TCBP) / Charge Air Cooler Temperature (CACT) Sensor are snug.  It's kinda difficult to check for bad turbos, though you might be able to visually inspect/test the wastegates.
Chilton has free manuals online for the 2010-11 Taurus that may help out with info:
http://hmcpl.org/databases/auto-repair-reference-center
Click on the INFOTRAC url, then click on Proceed to get to the selection box for manuals.
