Help!! How do I remove this tube?
askoncemore
I can't seem to get this out!!
What is the trick?.
Pics are not attaching.
I am referring to the bottom oil tube into  the front turbo and the oil pan.
What is the trick?.
Take a pick, scrape some of the dirt/ corrosion out, maybe some compressed air if you have some. Then Spay a lil penetrating oil around it, clamp on it with some curved jaw vice grips. Gently torque it back and forth. Literally like 1-2° forward, then 1-2°backward, rinse repeat.  Don't try to torque it too far. It also helps to use your other hand to help with the movement or even wiggle from side to side.  Curved jaw or v jaw vice grips work best for this.  They apply contstant tension to more of the pipe circumference which equal more grip. Eventually the baked in seals and corrosion will begin to give way. Just be patient...unless you can source a replacement drain tube quickly.
Sent from my PH-1 using Tapatalk
Mrhighcaliber is correct. It’s in there tight but just keep pulling. My front tube already had signs of being pulled on with pliers/vice grips so I grabbed on and twisted and pulled.
My rear one came out with no problem.
