southtxSHO
Member
Would our cars benefit from a higher stall torque converter? Would the transmission handle it ?
Just a thought. ...
Sent from my SM-N900T using Tapatalk
Just a thought. ...
SHOdded said:As it is, once the SHO is tuned (probably same for Flex, X, F150), the best launch rpm drops. Higher stall = no help.
SHOdded said:Brad, you are in the right area for launch with the tune, closer to 2000 rpm has been reported as ideal for most.
NMB, talking about the SHO or the Stang? What is your launch rpm, and what is the stall speed of your Circle D? Dyno sheet? 1/2 second is fantastic. How's your normal mpg look in daily driving?
Nice ......Tuner Boost said:We are about 50% through development of a purpose built unit (not a restalled OEM like the others I have seen) and on similar applications were seeing .4-.5 sec gains in 1/4 mile times...60' is really improved. Will post more as we near completion.
