You are getting some scary low fuel pressure in 1st gear and into 2nd before it recovers...Not sure if you meth is flowing that early or it takes time.
I'm not a fan on how that stuff makes logs look..One of the banks is pulling the max allowed amount of fuel with stft's and the other bank is not pulling the same so I'm not sure if the meth is even getting distributed evenly.
You are getting any KR but you aren't getting any spark additions from the knock sensors which is weird because you aren't running too much spark even with all the meth and you didn't log IAT2 so you can't really see how well the charge is being cooled.
you are commanding 220kpa and in 3rd after the 2-3 shift you are getting about 235kpa down to 210kpa which is a normal drop off
If your meth pump fails you will have a hard time supplying fuel.
And if you did a 3rd or 4th gear pull from low rpm not sure what kind of boost you are commanding there but if you are commanding the same 220kpa be careful because you may not have enough fuel down there.
