HOW-TO: 2015 Explorer In-Cabin LPFP Assembly Access
Ecoboost_xsport
So I was really dreading installing the fuel hanger that had installed the DW300c into.
Reason being...I was dreading dropping the fuel tank as we don't have top access from within the vehicle.  This would mean taking the driveshaft down, removing the exhaust, removing the filler neck, all kinds of lines, etc.  As some of you know, I hang out on here a lot and posed the question to see what you guys had to do for any pointers before I tackle the task.  You all proceeded to tell me you have in-car access from a plastic cover under the rear seat...ugh...I got jealous, LOL.
Anyway, I decided to say "&^%$ it!" and see what can be done from the top.  I took the seat out, cut back the carpet and found a small hole with a rubber grommet near where the fuel hanger would be.  I used my boroscope to see what was under it and see what was in the way.  Well, nothing was!  So I made an larger exploratory 2.5" hole that I could easily cap off with a rubber plug I had laying around if I had to abort.
y4mRJFIPWny0Z3p-uFyuKvJh_BZcVRjN-PiZO8yE5tk-rr7Z-YWMxT2zWx1JzCtGPAuQoiCC5jTTZ3DmEtjM2zWEgFzwFhYsjash37pOLxqepXUi6MGOr-hUXZW6e0RmDRL7JetJB-JYmTnX14SXta6XbSlDTd3ubTt5AmvABXJNNbu-yrYlTHwdgK3ZQftIvh0
y4m_0mMOI-tZUf_bQWW4HXJSKSPnrCkIlOdb48JPAzq60zxGVbUx0xHYZo9Gwe3tK_Y7RWGT7FcPT1Uj1M5SU57560AHgPC3d0oELlRnYKS2uOaaiU86x6tJwSiRhcVPCucfFsf_dupgOd5DIZ5V73yRzk01iUAYyH3GX4T5dZBE0yLMfEMFis_L3D_JPAX0KDL
y4mGh6QjxrzjnUWwMUUs9sP_pX5XFPXYjt1b49wbfL3hD4ly8f46v5Kqh8BJs7ztPFcEQgLA3-s71_wsdqXDFt3uNvb1qB3gzleGtPtVd73l9ntMOx4E-FKQkuscPFvNQLBEkPf9NWDP_HsW2AoGj7E78vXIzPFXZez3EtzSdNWbA6BgsAJiBPfyNRUbSc45i3t
So after closer inspection, I noticed there was parts of the body that are required for the actual structure, but there looked to be a small window I could make to access the fuel hanger without effecting any of the structural integrity.  It would be an odd shape, but it was a flat area that I could easily make a cover plate for when I was done.  Sooooo, I decided to just commit...full send baby!!!
y4mlQJlY1Y_sQYyKCXYKWoSwfC9CzWsGN0zVwVNJYta-3vr8m9LpoENfvllV1As1XQMaMXI1ZG0SQsS8-fXBpT-T_Cp2QqrVCOPo0sFPAK6V6-3vdTRWNIooLbwQdPnEECYvWfObadO46WtAiqrAsPUsgKaBgfDffIngft9CqO4v2ATzTwxCK_NFSyLdzk49pnS
Here's the cutting tools you should try to use.  I would NOT use a cut off wheel as it creates sparks and I am not sure how the fuel vapors are in that vicinity:
y4m5rKKdkQSo5RwJxllwvVSURTGpoChBF7Ps6C8ZzbUdQcBTXX-HGeKBExEcDZg8TGbq2-J2QWstMvf88mGY7dIczvDMopNK63eMhBwZlPwrhqnC1jv7yk4akKvRFgsZ-4nYasN7m2xRLwM082O-ngi22gWcpQR_R2X299NolTacKE0UUcUneSL2wqnkZHsDec9
Initial rough cut:
y4mCnJEJLSRWtLiJJ6K7tgw8cDndzpWXEOKCstOY2FCANwhrS7vmlg3NLhh4Qzff71g6ZjekAsveF_qQ5Sb2h52dZO9R0LM5gqkzwrDQTisvaOcL2wRY08Jek00Qw0ZnzENqftPg7tkgMIEhi9FeuxKZoyXxgg30f138ePxB97SG8LslLigzkQrw_Ex-s3yiJtn
Edges sanded and deburred, old hanger cleaned:
y4mzc8jAbBJSuCLGRpTRDui6vpQXORH9UKAkt5jzjEsTNiSQ1dfa6HJ1KLDNSCfioOJx12FP5-FUKwnucJ0hPSUFzuM6WyNFMw1-O6BpuNaq6j7xKsqSq9uv8xBnKOnemB75TjQ7-_P6Z4v1lSojyLVtaTfMrh53z2afvmniyvy1qW5uvpppMz6zt53GoC7lBpP
Carpet cleaned and trimmed:
y4m9mnOvAXCPpXIZRkveXpjCExxo4CcX6PINuUBF1qw2xsX0xWv7Iz73cPEkEhh3kmBI0TuPA0R_fOCGSUe_53KX4TbQQVlxwXY4Zqq0zbhxurntce8sYWLCfij8u9O-akLmTSiY1UYxGS675Ar8VXU2mH-5mfZNPuW8xIovfwuhSTYz7XKqXlPqGU4i-g27n3M
WeatherTech mat covering hole, to see how obvious it might when I would get finished:
y4medsf5osPIx5paenKkk92Vd3ay-FHQGQWyJR-YrFh-WS7qkvSQ6yjRUh-tIuLPqC4zxMitTgZTp8a8L87B4PjtZcK5LDR59xRs6Ft3FBO9DglkGYuKeBKJlHdT3YEnzfV-5_e02I3RqcNIUEYT2JEF7r_pCxiqaKhMxMeyWeU0I2kb2G6ndeXqsPRJ0KQA2wW
Well, Now I just would have to make a cover plate, which will have integrated gussets for added rigidity and a rubber gasket to seal it up.  I'll drill and install some rivet nuts and this thing should be super easy to access in the future should I need to!
So latest update:  I installed the new fuel hanger from this access hatch.  OMG, it was awesome how easy it was to get to.  Didn't take a pic of the finished install as it looks exactly like the OEM hanger, LOL. Oh and I used a new hanger o-ring too!
Cardboard template of the cover I will cut on the shears I have at work:
y4meQ0xxCcMAKVFidK9jfuVHrSzsXbBYp9k6FZ0WG-zmeykLW2-Uc3Sl8seDcsG_sAEBdXNYd2fgNp1H_0M25-S5YhVmbXstgxvUeNrTXdqCLI3qyrTJHmfSQJ7RsOKkuENaMs_MFleA9rEMNq1aqW9ab2Etpg3h5fhHSOxM31NVCRmosU8Ff2ZsYmBWtsW94Wf
y4mpEJOm5_qK1imW4-37jOY8UTrfOFfSTf11pzd7dhJ-vMvpcVKDQ7RIZ28AN3KHCnWQniY-VNJimhQgwdx-VnP41vFb6JwzrvVXx_Jvje4DCDboNacBG4usxwfsgYj0G_wnmgqFsLQledmua1P2yPbamqCiqicsXVY5-MyBnqmJ9_ZlHIJCXMK6tY7SbJlzNqG
y4mbQtlHU5NKMpBoZuG0NNU7aPlgjstY9z1dxdcyKnkXJUDUKgLkfru77s6P-RA1_5a2OMpHbAPhjH7quw9coBMTu_NK4YeYrBJ-QFjGySN8mbuge8HZjot3uwsxDTQG8yAlYxyWJluTXCI6R7RKGYOnFd7uR_cU3e9g7LHvFjrGzf58TpbiYErsacEbEgLshT5
Cut the new plate from 8Ga aluminum plate...pretty thick stuff, won't be putting the indents in as this is way thicker than the sheet metal body.
y4mkYAl717EiOKjEfiYXBZd0MAM7AyMkKyR6A6uX6WgwqRe0cKjvHTZg6LMIXTudMq9aDIdKKBIWw5RCfTveKFPHEOG5anuCeNGY4flOESZBOC13HwIJUAG3tjyUFlhGucgIPFjGzDmyFQahVXJ9WitLXzR2xgAmbwkk2mmmvAzI2mkq-hq_MDOePTrKLXjpd4W
y4m0Zfqi6pi1FLIyt83g7LVyxhXUQF0DBD215tA9ojXlmpvSd_nZeBwC_1wf-0wNwhpo0iy8LAYiJm8CkQlqpfxmOX9hW7HL7rcNAJJ8DymGVQLlgUcGmW5yMMbq3IWnWEphZq_Acyc0b62YzPqHV5MP1Y4Iu3RYiIXapaJ1DCNPVonfn8Ac2DCxCK9Xl1-ymNy
Comparison of aluminum plate to template:
y4mAue0eP7q-OdmYdUSmm5oaCOYwVQCfOmDLdkGwlGw6v6sdh-_uwjLGiA0ZoOT3yKya9a84x2FrcVO9ZHuPSNP9ReJaBNCafKhIhwZCX_h3rEvEj5CQoF1vJ0dKbdrkSIbsi_WRWPYd0ngzrgu5mQFcee3hLQrmClOkw5inSEuK-O_nDG0ICefNKPbfWVMywMn
Rough sanded and filed edges:
y4mZxMa5wynRaqEIv_043rp1kM7sF2RhIdjGqmssrY6Rf51SjlLZa1A5sNqZugZBiU6rjlUmLS0PaPpAaaJCUDsO3u9Cz3micbyQCJVZQ7g36X2D5Qd1j34tyEw3_Cj4BOIKJ8cj3ocw53XXE5DudeWlVWexzvoBQTLQ5N-0iVjWA5QiFkFxiUnPjgYHnO0YhnD
Fine sanded and polished edges with finished top/bottom:
y4m_uh10NjVzdBMpnqNkxA6XkM7ekhsV4vns5P4NbvihbxBpm86BKjpC6-_TK9MBpI7guRW9cS3hA5FSAp_iTSWPtEtv5iqaVw4gnLkr4naVd6V9Tpy2ZzogFdCSbwymFYvUqV2cnn4A5BcGxxcVV8LhtmdrlwkO3Rkzr-1Ruzg6_hVZBmxpNhNbj5a0hXJAg62
Mocked into vehicle:
y4mlNIFo6gWuCYY5aPHtM8KnwCW_3s5hG06vwP_v4i5ogtRgVM01NrTXBEQcGttwU9WrquWobDhGMvvc6CKkmXuwUl4FPzPDzd2ILLpZjpUqvxeJhYnXGkxQWr8_gRTI4j-5Skb_xv6WUmIa3CFQCqjCR-oyFS107vHXAWGwIBquZM1lAyDCe5LFcM8J8utE7vh
Gasket cut/sized:  Just need to identify where to place the hardware holes...
y4mVVMMG0CuVfiiPgL0Ttc18LCjctW7TCX0X5p9QMBEVWb2nT3NoYz7-F4ifKQipkaZEa5v4lxVi_TvKt-94cB3MG1Kzro91N-aVGaxvEvvvG6opPTUAXNGNoBcP7VgS3-KR4da7dJZix0tULFPLk1pMUjp_mCw1XEZFpBRppNbxy3cZDUHMWyzY_PoDI9BkW2Y
y4mf0jKpx_rWl5nUTB3049LqSP0WpiPGXIdOGjA76rt0Cfp6Dc4CBljw5qF6-Dei5ob4fXCatLt1o1CDN6HwUnzPhFbi1_0sTjajkHElFn6D38Vie4gqBvifWzZ0oQrk5swYecTxrboKd4U6mo3CXH4ePy1GhLOxPAGZ7noqxbB_NQFnLjL75qoB5sPZGC4YASe
y4msZy_8KLu0PA4a15P8KyzFnMeqWFDZVFwMxj8eJ6n8MzevlmmoXVgTt725iJeHpjkleI7xNT0cXw_KVjNM3-1yq5GK91ZuUxiHNp4L6XReVsJRNOW7t2mX4dQdgwG0EebhiXVa8lelPLfTExcStc3Ki97mj2pdjsuV9LrteAKp1I4ccWeYpP5tGXEBu4__GaV
Center punch panel bolt holes:
y4mjZ_Q3mLAooLInE9cuCloafXeG0qma8-hdCqeHOvbMmN1Id1AWPnqGct_KtVYuyc40-GN-puhhy_xjvMmETSCG1244QXPbXiub9L_8RJon0RHSJDmx65ZvWJKaXwExiW_JsuR43WAoompEpUziEKlRxiexJXY2bJ-72bR0RqYOiuxBl1tTyT56ni82fVxFvED
Pilot holes drilled:
y4mWL1_4hGVMrrbGbE-PwtOekW29VxVPFHGSqL4-caveLlInXwtQATeMa6_FSkadY89QvxXJGMIb3V5bOC10gAKKIFa0VYY9p3UtJUaMQVdA8y021PyrtGNNkXhc7GBgAz0HelfpEjqRjy20G2U2ichbnMBymr7OhX0nXW3Conxs9H3eZRMKaYTbeMNPzoTQnQt
Transferred hole locations to gasket:
y4m1_QMJObBQ9eQ0a-etlPfbgI7VV1KDiFHyfCoOVoxs_BipY7zvrr5Ibt8sEWIhU8Mu6nxVhfxpwL8Xr3ORIzDG_QPng2I_N8z75jmA_EMuzCEHby6w7lOYHul8PQ7i_9tU60mtebayiDUN5wAjIaixpYY5uUTarm_9nprGZ2SrSpJ7Uc-rEVfqAXz4V3iAe6g
Holes punched into gasket (yes to the Crocs!):
y4mUr6ZstfBmDNmsf9npOHaPrEcij6b4fUggMEfsomRjxKNprRqqcbvCRl0RqEjfAQm2tSS_aqlAKMw32qC2p8ziRYQR2Z9ozLnuO6zr9dKniMvyKu6BumBqXZTnnPvv02qQuCL3EaPvhhV942M6kCT7RKt9tuqKnNFTgfEkA1nF3jKFqqSlTxalg6KQO91fB0c
Rivet nutt holes drilled in body:
y4msH4nmoIrx3dez10cxV3Z_G-a1tmZPCljmCjIfVAMjhiefGQ2pyumspvlGlKl_WUIyiKjT50CCnFyiT2RnmyJhie-4QDspWZVyBgawFf9qQSt3LdcItKwIhrWTakQNqu1gGMtLhXNkfA2_u3aQTZTHxeSH9EZgbzf9GO2fDGyNnvJ8MDblvadmd6A9yx7fgvv
Rivet nuts installed:
y4mupjb967ewEdudCNUIkhl5mL4aAY7EJqcLGxGEyvXPKRKAiI9eTC0EHVZZEpvldsD0zLySqXARe4lqrTyG51K7rW4iJs1cE9GdnQm2T--4jBh1A81A6E7BYMMN-JdFxHRR3SUx1bdcNXbXEN_Pm8as4SHxt_kNVFw-0WVmgUHUSlpcLkQ5C1TDhdmCV2byQGe
Had some DynaMat laying around..helps a bit with sound deadening
y4mPGEGvRIM4mP7bNuSQRRXkftRYvVQdfWdWYlaOUGmLpq4N7529BPOawAkK-boO-7ALtP6HbDk5z8xlSTZAfhdwmiivihP2vSLNGmFk8S4-6nWGRhUtpZT_ZHjWCA3Iehipwsdm68TcUEEwRRV106-cyO913EGKggPdvfaWlNzK0ySo2ejKf51HrkBY7D1KEqf
Panel installed:
y4mPTcUbh4G_jmdjPjxC-88dP7KLlG_PPk2CvXZ_PSmhr3RYuEcRTLFHmMnNs_eyrVyljEQWZlqsjH4_TCPDvgYKh81M7BVA11gtcMVuQTAg6nRbZzLTc303mf8oF7TQPg1y59aBMcKN1rBlaq8Ulf_UmX9qVbiqBtw-xrqghT6qwOIhjrNESLFB5tWLCntmTx3
Hardware used:
y4mwtlV9p7ZFyGFqyV0BS0ZyoqcThBikZapOVM_LiD6-zxBPTfUYviSMw93iLcvZCVKe34tjsqvj34WB7h1WipStlG2EsUrTOdZPkJN74B55c6ZegUacRyPVvJhuTEKPWOfgP52Y4KgZQQR4_E7D8-lij0q0dlDSwIeGxJCftcRRZukzeFQeWsnZ5U9tq4JcLhy
Seat installed:
y4mGb3ANz7BrQtUK8kZKwmvvrglRSI11UGWGyN1VcJUa6vAZq2gMxZuI0P4X6jA5XqZYLLLOKEszvJqMa-hVUVDsBQuX85Y7keWEyUSFLnQLJms5P5y-iVSjfkwb1duETryC9k0fiOZMuTTrph8LYtKKtM6C97JUeXXTWJVAM6I3CHF_WCVOqPm9T37Kohj_meR
Easy access when needed!!:
y4m4iBOsWwR5CA-J4I99qz0mXrt8Bgu840R6LggflHPcImAPtsbtPU_SN9w5jqVmCwPxOCx_uK1dQfc8ePd9g6ETfl9jwx1zuEEyx3-RofwsqpaIT-OH_Qb5ynz0S9gcxz9dH4Qrrm0c4nlVXs7De2KkfK1Jz9IQpju_3oizYi5VHnQ1hOaE8SaC0XZGAVVtd44
Bravo! Bravo!
Applause
Most impressive custom, one off craftsmanship to the Nth degree.
Well executed kind sir!
