"How-To" 5000K Switchbacks and sidemarkers installed! - ShoBoat
kbeck59 said:
I Highly suggest that  With an aftermarket HID Kit That you use  a Relay Harness So POWER comes straight from the Battery ..
VLEDS sells one for the Kit you want ... http://www.vleds.com/morimoto-9006-hb4-relay-harness.html
The factory wiring on none HID Models is usually to Small for the extra amperage demands of HID's
SO NO they are Not plug and Play ..
Not hard to do ... take your time and don't try to rush it
On My 2011 Fusion Sport I Installed  a HID Kit  . I would install the Ballast's  Behind the Lower Bumper area away from the Elements  . It is Fairly easy to remove The Plastic Shroud below the front of the car  . I did this when I put my lower Billet Grill on my 13 SHO.
I bought that relay harness with the HIDs, which may be adding to why I am so overwhelmed with all this wiring I am staring at
Don't let the diagrams and wires confuse you. Determine what attaches to what.  Then locate these point in the car and on the harness. Next locate the physical areas in the car.  Now you know how to connect it.  Finally consider how to route the wires and when you're satisfied begin the install.
If you are worried you can't do it correctly and the vLED folks can't clarify it for you I'd recommend getting a professional.  All of us do from time to time as we mod.
Hey Guys, I would like to apologize. I realize that a few of you had sent me some questions regarding this mod. I have been otherwise occupied as of late. The V3's are the way to go, I installed these in mine about a month ago. With any SHO that has the DRL active you can reprogram the ECU to activate the turn signals instead of the headlights. This is cool in itself. But the V3's change to from amber to white when this happens. so your DRL turn signals are now white until the signal is pulsed by the indicator stalk. How cool is that! BTW BIGMac nice ride!
Thanks ShoBoat! .... I Agree on the signals... VLED is the way to go. Here's a link to the install and a demo video of them working... compares OEM to VLEDs.  some where lse I posted the content of the package... just be sure to get the Ford adaptor!
http://www.ecoboostperformanceforum.com/index.php?topic=1730.msg22650#msg22650
I'm still having problems with mine after trying the new model ford adapters.  Its been so damn cold I haven't felt like messing with them any further yet.
Can you be specific on the issues? I had a few also maybe I can help you out.
Same here... what exactly is it doing? I am having no issues.
I know you purchased before the adaptor was available and got it later
My guess is that you need to check the pins inside of the waterproof sockets were the harness plugs into the power brick or extension . One of the pins in the socket was pushed back some and was not connecting on mine.
I pulled it out with needle nose pliers and then put a drop of super glue on the back side of the pin wher the wire comes out of the socket but behind the round colored grommet ..
It drove me nuts till I figured it out and I had actually forgot about it .
Unplug all of them and visually check that the pins are not pushed in.
It's not immediate or every time now but they will still switch to hyper flash and disable the output until I turn the signal off and back on again.
1: signal, normal flashing a few times, hyper flash with output disabled (switches back to white instead of hyper flash amber)
2: signal, instant hyper flash with stead white again.
I even tried it without the resistor and it still does it which confused the hell out of me.
I need to get forscan hooked back up and see exactly what error the bcm is setting.  I presume it's disabling the output on what it thinks is a high load. It also seems to be worse with the engine running at alternator voltage instead of battery voltage.
It sounds like a defective control unit.  Hopefully it's still in warranty.  Maybe give them a call and see.  I found them very helpful.
