I thought I'd put together a thread to discuss my auxiliary fuel system. People have asked for a kit but I don't know if I could do that without becoming a vendor on my own forum so that's out for now.
Why would you build an auxiliary fuel system?
The existing fuel system is out of fuel pretty much with a tune, if you want to support running of E85 the car just can't keep up. By adding fuel injectors to the stock manifold can spray E85 in the intake manifold to supplement the stock direct injection fuel system. The spraying of E85 in the intake manifold also reduces the air temps going into the cylinders and cleans the back sides of the valves of all the gunk the builds up due to the ethanol in the fuel. E85 is a great fuel to run on boosted applications and allows for quite a bit more timing to be ran due to the anti-knock capabilities of the fuel. E85 in a boosted application is just AWESOME, there's more info this board for reading up on E85
Parts of the system
Fuel pump and tank
There's a couple of options:
I am currently working with SplitSec.com to provide an AIC1 with the following capabilities.
On my current install to get everything working I had to use an MSD distributorless tach driver which meant I had to pull the fuse box and cut the main power for the coils and send it through the MSD box. I don't like the idea of that, a simple wire to the #1 coil would be much nicer. Why not just feed with a single coil feed? The existing AIC1 would think you have a 1 cylinder motor so it won't spray nearly enough fuel.
Intake manifold modification for auxiliary injectors
I currently have a guy who did my intake manifold and he said he could build more, the whole modification process takes about 30 - 45 days as he does them after hours on his own time. The wait is worth it though as he used to be the main fabricator for AZ Speed & Marine, he's actually built prototype manifolds for Chevy! The manifolds come with bungs and fuel rails and mounts for the fuel rails, there are two sets of mounts, 1 for tall injectors and 1 for short.
Fuel lines
The fuel pump options need to be finalized (should have this answered this week) before a fuel line setup could be configured. I went down to the local Parker store and spent over $450 just on fuel line fittings. It's super expensive, ordering off the web would take a ton off that price however.
Costs for the project:
In tank fuel pump - $600 to $1000 depending on what fuel pumps you want to use
Under hood fuel cell/pump - $100 for the tank, $112 for the fuel pump
Fuel injector controller - AIC1-6 - around $450 or so, still working on that with them
Intake manifold modification - around $700 with intake manifold exchange. The best case scenario would be to get a group buy going to Bryon could do multiple manifolds at once.
Fuel lines - $400-$800 depending on what needs to be done there
Fuel pressure regulator - $90-$$$$ depending on what is chosen.
I'll update this as I know more but this is the current path for E85 until somebody makes an upgraded cam driven fuel pump and high flow injectors.
Parts of the system
Fuel pump and tank
- I am currently using which is to mount a 1 gallon Jaz fuel cell under the hood and use an external Walbro 255 lpg fuel pump along with a boost referenced fuel pressure regulator
- Another option is to upgrade the in tank fuel pump and go with dual fuel pumps, I am working on this option with Squash Performance. I would really like to get rid of the fuel pump under the hood and fuel cell there as well. Either looking at dual pumps feeding a single line to a fuel pressure regulator under the hood which splits to my nitrous, port fuel injection and the stock injection OR one pump dedicated to the stock fuel system returnless with another pump dedicated to the auxiliary fuel system setup as a return type. I need to talk to Andy at Squash to finalize this and order as soon as I can.
- Control 6 hi impedance injectors with EV1 connectors
- Built in coil per cylinder circuit for correct RPM detection
- Throttle Position adjustable circuit to turn on the 2nd fuel pump if that is the option that Squash and I work out
- 5V output and 0-5V input for Auto Meter 2246 fuel pressure gauge
- I'm working really hard for him to put a bluetooth serial connector in the box so people don't have to run a cable inside the car.
Fuel lines
