How to go about new performance tires?
While most synthetics lubricate well... I use Amsoil Signature synthetic... Because it surpasses about everything in it's NOAC volatility rating.  This is important int the 3.5TT GDI because ford empties the PCV blowby directly into the turbo (front) intake  pipe. I don't want my turbo coking up... I also went to VTA on the BoVs to avoid recycling that stuff through my turbos.  Most people with a really working catch can have posted here about all the volatilized oil that condenses in them.
So I do like Amsoil Signature and go to the trouble and expense to get it... I have 100k prepaid maintenance on the SHO through Ford... I take them the Amsoil at oil changes because I believe it is worth it....
but shouldn't we be talking tires in this thread?
Yes big mac we should lol....but u are spot on amsoil signature is great oil it's all I use...I'm a freak tho because I put it in my lawnmower. If u get a preferred customer membership u get amsoil at wholesale price and it's really not bad and if u use the oils the length of time recommended it's really not anymore than what's on the shelf cost wise
Sounds like Amsoil it is I was actually recommended Shell rotella 5w-40😳.. And I ended up going with Nitto Invos for tires got a good deal on them. Thanks for the advice fellas.
Welcome fellow houstonian, maybe ill catch you on the road......
:jacked: I use Pennzoil Ultra Platinum 5w-30 full synthetic. If it's good enough for stock, Ferraris, SRT Vipers and Hellcats...then it's good enough for the SHO. Uhhh tires...I'll probably switch over to Michelin after I burn through the crappy stock F1s.
Sure it's good enough but there is better stuff out there if u want the best.
And it's really a loop hole and a technicality that some of these oils are allowed to be called synthetic as they are still just refined petroleum  and not a true synthetic base stock as in a group IV/ V
I was considering ultra platinum and amsoil for my oil change in 1000 miles. Looks like I'll be going with amsoil. But I guess anything is better then the motorcraft full synthetic
