How to Install 3 - 7" fans Behind the Grill 2011 SHO - W Custom Grill Only
Finally finished up this install,  ;D
Hard wired the Fan set to the Battery (with 25 Amp Fuse inline)
Installed a Push button On/Off Switch
ordered up the Battery Jump/Start Pack ProSeries (Model PSJ-1612-CA)
Picked because of 22 AMP Hr battery set (should be able to run the fans for 2-3 Hours Total)
Nice. I'm sure you'll have great results. After my recent experience at the track i'm almost wondering if this setup isn't overkill though. with just 1 of the OEM fans running and hood up my IAT's dropped to the low 100's in about 30-40 minutes.
If there's not many cars at the track and you're pretty much gonna hot lap i could see needing a bigger setup like this though. Should cool the heads and block real quick!
Since I only have about 110.00 In this total,
It is a no Brainier - I hope 15 to 20 Min Cool Down
Will be doing Test and tune 1 or 2 Sundays in Oct to test the results....
