The My Ford Touch wallpapers can be gif, jpg, png, and bmp with a maximum file size of 1.5MB.
Wallpaper Dimensions are 800px x 384px.
1. Load the wallpaper images on a USB Drive.
2. Insert the USB Device into the USB port in the central console (under the armrest)
3. Select the Settings Options
4. Select Display Options
5. Select Edit Wallpaper
6. Select "Add" and then from your USB device select what images you would like to import. This will just copy the images from your USB drive into the MFT system
7. Once the files have been uploaded, press the back arrow and then highlight the image you want and select Save.
8. Select the Home button and you should see your image now appear!
