FiveLeeter918
so do you need 3/4" or 1" caps for this? I've seen both, and want to make sure I order what will work best. The 3/4" O'Reilly and NAPA have in stock, the 1" I have to order online.
1 INCHFiveLeeter918 said:so do you need 3/4" or 1" caps for this? I've seen both, and want to make sure I order what will work best. The 3/4" O'Reilly and NAPA have in stock, the 1" I have to order online.
ZSHO said:@FearlessAZ sounds Nice! fixed the above video for ya. Z![]()
Welcome there Mase!! Do you have any pics to share? It sounds like your wastegate hose is loose or popped off!!Mase said:I know this thread is older than time but I just got done reading the whole thing and have a couple questions. First, I noticed some people are running SSQV in place of factory BOV...curious why and how they did it? Second, like some others have indicated, my SHO vents sometimes under light acceleration. This is a bit frustrating as I am pretty sure it should not be. I am wondering if I didn't hurt something when I originally did the mod because I blocked off the BOV and returns accidentally. This made that very cool sounding surge but pretty sure its horrible for the car! How can I confirm that my BOV's are ok and if they are not how can I/should I go about replacing? Thanks for any help you can offer!
ZSHO said:Welcome there Mase!! Do you have any pics to share? It sounds like your wastegate hose is loose or popped off!!Mase said:I know this thread is older than time but I just got done reading the whole thing and have a couple questions. First, I noticed some people are running SSQV in place of factory BOV...curious why and how they did it? Second, like some others have indicated, my SHO vents sometimes under light acceleration. This is a bit frustrating as I am pretty sure it should not be. I am wondering if I didn't hurt something when I originally did the mod because I blocked off the BOV and returns accidentally. This made that very cool sounding surge but pretty sure its horrible for the car! How can I confirm that my BOV's are ok and if they are not how can I/should I go about replacing? Thanks for any help you can offer!
Is there any noticeable decrease in performance?
Due setup in INTRO when you have a chance,thanks. Z
Mike.B is da man if your interested. ZMase said:Wow...them pipes are sexy! And that Direct port injection...very impressive. I just got done working with Jason at Livernois about that...just cannot afford all that with as little knowledge and support I have in this area LOL
Curious why and how you went with the Tial? What kind of pipes are those? VERY nice!
Mase said:Really at a loss what could be causing it to vent only under light load. I have thought for the longest time it was just a symptom of an automatic car but it seems more and more like I might have hurt the BOV(s) when I fudged the capping of all four nipples...
Do you have a pic? Interested in thisWoody said:As another alternative to those interested, I only disconnected from the BOV side and left the intake side of the tubes attached. I then found the appropriate size "plug", which turned out to be a 1/2" PVC Cap. I pushed the caps into the tubs and pulled the clamp back up over the caps. Seems to be working well so far, and should be easier to reattached to stock if I want to for warranty work.
