Intercooler help?
WaelSHO
Hey guys,
So living with an Ecoboost in a hot country kind of seems like its killing the car.
Sometimes when I'm driving at a little bit of a high speed and want to kick full throttle, It's like the car stalls, lags, I don't know, but it wouldn't change gears like from 3rd to 2nd for example. Instead it would run on the gear it's already in, which in all honesty is killing the transmission and the power a lot !!
So I was thinking of intercoolers and if anybody has tried any.
If there is someone who actually tried or is already using one, please help me as we are over 70 people here suffering from the heated power.
Basically we are an SHO group in Saudi Arabia, and we all love the car and are big fans of it, but the power failure sometimes is a bummer and the highest temperature here reaches up to (122) Fahrenheit in the summer which is a lot.
Thank you all for your incredible help !
So I may not be the best person for information when it comes to the SHO as my knowledge is limited to the Fusion but I'll give it a shot.  Also, not sure how the shipping would work going over there as it would have to go to an APO I believe.  Some of the companies we have to go through are linked below.  If anything, it gives you a reference to start with.
www.levelsperformance.com
www.cp-e.com
www.atpturbo.com
I'm sure there is more I can't think of right now that I'm missing but hopefully someone can chime in with some more vehicle specific information.  I have the Levels Performance which is owned and operated by 1 man doing all the work himself.  It may take a while but the quality is amazing.  Maybe message him and see if he can do the piece for you.
Hey !
Thank you for your response, however the only problem I found is that all 3 links have nothing to offer for the Taurus SHO, for that I'm wondering, can I install a Fusion intercooler on the SHO?
Thanks !
As far as I know, the only intercooler replacement for the SHO/ Flex/ Explorer comes from Black Market Racing.  However, its only on one vehicle, and there's been no real evidence of any improvement with it (to be fair-also, no evidence of any lack of performance).
I would suggest that if you have concerns with heat, its probably best to consider meth.  For cooling purposes you can place you nozzle just after the CAC.
Methanol injection is usually a good way to make power/keep intake temps low.  Keep in mind though the placement of the tank should be somewhere that stays relatively cool.  Methanol has a lower boiling point than water - 149F (65C) or so.
I'd talk with Mike (EcoPowerParts) and Black Market Racing (mentioned above) to see if the intercooler they have is feasible for you guys.  You might also want to consider heatwrapping the pipes with adhesive foil, such as MDesign uses for its' custom intakes.  Not as good as a meth injection solution (in more ways than one) but DIY and relatively inexpensive to try.
Some of us have zero interest in running meth. Meth is sure to create warranty headaches and there is no denying you are tuned.
An intercooler solution without a bumper modification (voids a major safety factor) is not possible.  I have said before that with some body work to strengthen and extend the frame (and hence the bumper), you could make as much space as you want.  But modification to the (or a completely new) bumper fascia and wiring adapters etc. would be required to go with.  Not a small undertaking.  I think in that light, meth injection is not so bad.  Plus you get the bonus of clean intake valves.
I have a slight interest, but wont entertain meth until the warranty is up.  That said- meth is still a better solution that an upgraded CAC... even if an upgraded CAC did exist.  I'm just spit balling here- but a small, fine mist nozzle just after the CAC would probably not require a tune.  Now, if there were performance gains above what the stock tune can handle (significantly cooler air, or octane boost) then obviously they wont be realized.  Of course, if you're going through the trouble of plumbing the lines... may as well add in a little extra (second nozzle closer to the TB) to make sure there are in fact performance gains.
Thank you all for your care and response.
As for the engine cooling, I am looking into meth, I've already installed a 170 thermostat so that's out of the way.
But what really concerns me is transmission heat, I've drag raced a few times a few days ago and realized the transmission heat is rising to a 95 C temperature, which is a lot!
So yeah... any ideas on this would really help.
Thank you
I didn't see you post what model year your EB is, and as important, whether or not it is PP equipped, or is a Non-PP.....
However, if your primary concerns are with the heat of the trans and it's fluid..... You would be wise to retro fit the auxiliary trans cooler to your EB. Assuming that is, it isn't equipped with one already.... (see my opening reply).
The auxiliary trans cooler is a Ford product.
It comes as standard equipment on 2013 and up PP Equipped cars, as well as on the police pkg versions.
It can easily be retro fitted though (for those EB owners who are Non-PP) and will significantly reduce trans fluid temps.
I was the 1st to retrofit this quite a few years back, and there is a step by step "How-To" tutorial I authored on it's install. Check the "How-To" section.
Someone also recently posted about changing out the thermo I believe on the auxiliary trans cooler's bypass valve for even potential further temp reductions.
If you can't find the "How-To", or the recent posts on changing out the thermo on the bupass valve, ask SHOdded..... he's really good at digging up that kind of stuff.
Good luck.
Oh, and btw, Methanol is great stuff, and Meth users typically see an .4-.6 quicker in the 1/4, not to mention cooler IAT's as well as cleaner valves and what not, as it's use will counteract the deposits known to develop in D.I. powerplants.
Good luck.
Links to the How To for the trans cooler:
http://www.ecoboostperformanceforum.com/index.php/topic,522.0.html
http://www.ecoboostperformanceforum.com/index.php/topic,2008.0.html
Some more pics here:
http://www.ecoboostperformanceforum.com/index.php/topic,5389
A post on replacing just the transmission thermostat/valve:
http://www.ecoboostperformanceforum.com/index.php/topic,6585
I highly recommend anyone looking for "How To" information to start in the ... "HOW TO" subforum :D
Forum > General Category > How To Articles
When you search for information, you would want to start at the "Forum" (top) level, because search is context sensitive, and will only search at that level and below.  So if you are in the HOW TO section, it will only search the HOW TO articles.
Man you guys helped so much.. thank you for that
My car is a 2011 SHO with PP ... but as you mentioned, aux trans cooler only comes with PP types from 2013 and up... I will be looking into the links SHOdded has posted, and will get back to you guys ASAP.
Thank you so much :)
Thats great you changed to a lower 170-stat but would also flush out the coolant and would add this to the mix based on the owners manual especially if you live in warmer climates which should help in your situation.  Z..                                            If you drive in extremely hot climates: • It may be necessary to have a Ford authorized dealer decrease the coolant concentration to 40%.
A coolant concentration of 40% will provide improved overheat protection. Engine coolant concentrations below 40% will decrease the corrosion and freeze protection characteristics of the engine coolant and may cause engine damage.  http://www.fortau.com/engine_coolant_check-163.html
WaelSHO said:
Check this.. So I went searching online for a trans cooler.. Ended up finding this.
Is this the one ? It says on the website that it is not compatible with my year model (2011).. should I look else where? Or it would fit anyways?
Thanks
http://www.ebay.com/itm/BRAND-NEW-GENUINE-OEM-AUTOMATIC-TRANSMISSION-OIL-COOLER-2013-2015-FORD-TAURUS-/231915536421?fits=Make%3AFord%7CModel%3ATaurus&hash=item35ff3e4025:g:GY0AAOSw6oBXEmlX&vxp=mtr
Compatibility is listed based on OFFICIAL use & fit, so naturally it will say not a fit for your 2011.
These are the latest part numbers I know of that you should be looking for:
DG1Z-7R081-A - $52.85 (bypass valve & lines assembly) #6 in illustration
DG1Z-7H322-A - 30.22 (bypass valve only) #9 in illustration
DG1Z-7A095-D - $126.34 (trans cooler) #1 in illustration
Thanks for the reply... will do my best to order one too... and plus for the 40% cooling water... it might not be as good to use here... because in the summer the weather goes up to 50 degree Celsius... but in the winter it goes down to a max of -2 degree celsius... plus its a very dry area here.. so the winter breeze is messed up, for that, I personally think that at the time being, a thermostat might be just enough.
Speaking of thermostats, please check this photo, I took it like 10 minutes ago, is it me? or is the temp gauge is going down a little bit more than the factory one be.
Thanks !
